Old 08-11-2009, 12:24 AM   #1
AJLChase
AJLChase's Avatar
Cab rear floor crossmember
Has anyone had to replace this part of the underside of the floor? I finally got underneath my new truck and found that both sides of the crossmember have rust through. It doesn't seem to be contagious to the actual bottom of the floor pan but won't know till that piece is gutted out. Is this a hard piece to attach as I'm sure it's a job for a welder? If this is rotted out, how likely is it to spread and how soon should it be torn out and replaced? Also, if it's not too much to ask...what would be a reasonable price to pay to have a professional do this? Thanks!
AJLChase is offline   Reply With Quote
Old 08-11-2009, 01:12 AM   #2
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Re: Cab rear floor crossmember
is this the cross members on the frame or do these run front to back under neith the floor? im confused and pics would be nice if you can!!
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 08-11-2009, 01:27 AM   #3
AJLChase
AJLChase's Avatar
I believe this is what I'm after, as from underneath the truck this is what looks to be what is rusting out in the corners item #16
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=22
Old 08-11-2009, 01:34 AM   #4
pebbleboy
Son Of Gravel Man
pebbleboy's Avatar
goodmark has the ends for it
4142-571-601L SUPPORT, CAB, REAR, LH, 60-72
C / K TRUCK OE-STYLE
24.15
EA Yes GROUND
4142-571-601R SUPPORT, CAB, REAR, RH, 60-72
24.15
EA Yes GROUND
Daily driven 70 C10 longbed
Its a work in progress
Originally Posted by Longhorn Man
What one man calls a budget part, another man calls his entire budget.
pebbleboy is offline   Reply With Quote
Old 08-11-2009, 04:07 PM   #5
shaneo2112RUSH
Junior Member
that is a most common rust area. i would think the cab corners would be rusted as well!! but as far as repairing it depends if your willing to tackle the problem yourself, have the tools, alittle know how, and a welder. or shop around and get estimates at auto body shops. as for me i would repair it my self and save some cash! First you might read FAQ Thread on panel repair to see what your up against
Old 04-19-2013, 06:44 PM   #6
elf w/capital T
I had my rear ps rusted so far in where the normal replacement piece was tree inches too short, the rust went so far where i cut out another three inches past where the rear cab mount goes, got a full crossmember support from gmcpauls, cut in half only because i already replaced my drivers sidesupport, and cut, fit, trim, fit, trim, fit, now working on the floor yikes, should have just got the whole floor assembly...but, hey, first full restore, many lessons learned!!!
elf w/capital T is offline   Reply With Quote
