Old 10-15-2019, 07:19 AM   #1
6t727t2
Active Member
shroud restore
Since fan shroud is out now and in good condition, anything to do besides scrub down? Armorall, clearcoat, ?
6t727t2 is offline   Reply With Quote
Old 10-15-2019, 08:27 AM   #2
Jrainman
Jrainman's Avatar
Re: shroud restore
depending on the type of plastic you might have to prime first, if your going to apply any type of coating ,if you were going to clear coat , I would epoxy prime first , you might even need to use a adhesion promotor again depending on the plastic. they are also plastic restore products out there like for ATV plasticc but again you need to know what type of plastic you are dealing with , you might want to have this thread moved over to the paint section, the body and paint guys could give you a better idea in how to do this.
Jrainman is offline   Reply With Quote
Old 10-15-2019, 09:16 AM   #3
68panelman
68panelman's Avatar
Re: shroud restore
Personally I would never paint a fan shroud. They clean up really good, and if you desire to, put on a plastic/vinyl protectant.
68panelman is offline   Reply With Quote
Old 10-16-2019, 12:06 AM   #4
Boog
laying low
Boog's Avatar
Re: shroud restore
Since my shroud was an old one I scuffed it up and painted it satin black. It turned out great.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-16-2019, 12:48 AM   #5
YBNORML
YBNORML's Avatar
Re: shroud restore
I did the same thing. Turned out really good and doesn’t stick out like a sore thumb anymore.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 10-16-2019, 05:29 PM   #6
jaros44sr
jaros44sr's Avatar
Re: shroud restore
Harry, wash it with soap and water, dry and spray some WD-40 on it, step back and see if you like the shine....What are you building anyway?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-16-2019, 06:58 PM   #7
FirstOwner69
FirstOwner69's Avatar
Re: shroud restore
I cleaned mine thoroughly then used Son Of A Gun Protectant. Just wipe it on, don't let it soak too long and wipe it off. Shroud looks better than new. I did basically the same with my underhood A/C 'box". with the same result.
FirstOwner69 is offline   Reply With Quote
