Old 09-18-2010, 08:35 PM   #1
cyberpine
cyberpine's Avatar
87 TBI to Carb conversion
Anybody take this on? Good Idea? recommended parts? What can I expect to pay in parts and labor?
I have an 87 with a 305. It currently has a Edelbrock intake and Holley TBI. It once ran strong, but we can't figure out what's going with it.. it dies when hit the gas. It's now stumped two mechanics.
Can I stay with my Throttle Body Intake? I suspect not. Should I go 4 barell?
More pics in my project link below.
Thanks!
JC (Cyberpine)
My 1987 C10 Short Bed (click on slideshow to see full album)
cyberpine is offline   Reply With Quote
Old 09-18-2010, 10:10 PM   #2
ratty 46
Re: 87 TBI to Carb conversion
I'm in the mix of this swap in my crew cab but with a TBI'd 454 to carb. I've picked up a carb, intake, MSD distributor, some twin flo-masters & I'm hoping to get a single feed gas tank that I'll be using a electric holley blue fuel pump with.
I think the 305 will respond the very same way. Don't forget to remove the computer from under the dash .... that controls the fuel, distrib., all those xtra wires after you remove those parts.
You'll end up removing some extra vacum stuff too.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 09-19-2010, 01:05 AM   #3
rfmaster
rfmaster's Avatar
Thanks!
Did any one bother to perform a simple fuel pressure check. 9/10 TBI 'stump on the gas' problems can be traced to a low fuel pressure. Low fuel pressure can be due to tired pump, clogged fuel filter or bursted in tank fuel line - between FP and outlet port. These one are tough to spot sometimes as fuel gets warmer leak increases starving fuel injectors from fuel.
If your engine fires up and idles ok, but begins to stumble of idle then there is no good reason to tare off top half of it and replace it with venturi mixer. Today's techs are spoiled by advance diagnostic aids, but they can not think through a problem most of the time.
Going to a carb is bad, bad idea
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 09-19-2010, 10:23 AM   #4
cyberpine
cyberpine's Avatar
The fuel pump, filter, tank and gas were all replaced. Fuel pressure is fine, but we did have rust in tank at one point. Mechanic pulled up the TBI and says injectors are shooting smooth and consistent.
This last mechanic checked that the IAC (Idle Air Control) sensor was clean and will check the gas filter again.
My check engine code has alwas read error 34. Map Sensor voltage low.
We are thinking of changing out the Throtlle body Position Sensor (TPS).
By the way, can somebody confirm exactly where the TPS and IAC value and MAP sensors are exactly on my truck on this grid?
Many Thanks!
JC (Cyberpine)
Old 09-19-2010, 10:58 AM   #5
RandyP
Getting Old; Going Broke
RandyP's Avatar
IAC
TPS
MAP
Snuck another question in on me. MAP sensor is on a bracket right above the passenger side valve cover.
I know the TPS is on the passenger side of the TBI unit itself, 3 wires, I can see it on your bottom photo. The wires go up towards the breather assembly. I have the Holley TBI as well, and the TPS was bad on the brand new unit. Now I think I'm fighting dirty gas tanks since the fuel filter looked so nasty.
First I gotta fix a valve cover though before I can keep trying on my TBI. I'm very close though to yanking off the new Holley and putting the stock TBI back on. I got the same intake, but a 350 with more ponies, and my mechanics are saying it is throwing way too much fuel compared to the stock TBI, running very rich all the time.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 09-19-2010, 12:37 PM   #6
68 TT
Still plays with trucks
68 TT's Avatar
How did they check the fuel pressure? You do not have a test port. You need to add a gauge fitting to the supply line next to the TBI unit and connect a test gauge to it. Put the test gauge on the cowl panel where you can see it while driving. I taped mine to the windshield. Do not put it inside the truck whatever you do.
As RF stated the pump may be fine when cold and first started but may lose pressure when it warms up. I have had two do this to me. I was able to see the pressure drop once the pump warmed up.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 09-19-2010, 02:24 PM   #7
rfmaster
rfmaster's Avatar
Many Thanks!
Locate and a take a close look at your MAP sensor. It should have three wire connector (usually with a green tab) with the following three wires:
PIN C Gray +5Volt supply
PIN B Light Green MAP signal (to ECM)
PIN A Purple (or brown or sometimes tan) Sensor Ground
Disconnect connector, with ign on, engine off, measure voltage at Pin C. It should read 5 volts. If there is no +5Volts at PIN C look for harness breaks or bad connection between wire and pin inside connector.
The other common fault is open circuit at PIN B - sensor output never reaches ECM.
Changing TPS at this time is a waist of money. You can verify if TPS is functional without removing it from TB. Just disconnect harness connector and measure resistance between C & B. At idle throttle position you should see about 4.5 kOhm and at WOT should be about 0.9 kOhm (or 900 OHms) resistance should change smoothly as you move throttle shaft between the two extremes, Final check is measure between PIN A & C - you should measure about 4 kOhm.
To do these simple checks requires DVM - any parts store should have one for less than $20. Learn how to troubleshoot and post your findings.
//RF
"The Beast"
Old 09-19-2010, 01:51 AM   #8
68 TT
68 TT's Avatar
Don't give up on the TBI yet. You need to data log the engine while it is running and see what is going on. Without that info any mechanic is just guessing at what is wrong.
All you need is a data cable, a laptop and a piece of free software to read the data with like TunerPro RT.
http://www.tunerpro.net/
The guys at thirdgen.org have a bunch of great info on DIY PROM tuning and data logging is part of it.
Old 09-19-2010, 11:32 AM   #9
joe231
joe231's Avatar
hmmm, it seems you and Randy are both having map sensor issues and you both have the Holly TBI.....coincidence??
In my experience with this era of TBI, nothing works better than stock parts.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-19-2010, 12:08 PM   #10
RandyP
RandyP's Avatar
$400+ mistake on my part. All I could see was the BIGGER BETTER FASTER MORE HP! part. After the install all I see is JUNK DON'T USE STAY AWAY WASTE OF MONEY! part.
Old 09-19-2010, 01:00 PM   #11
joe231
joe231's Avatar
It happens to us all, AFAIK anyway
CHEVY ONLY
Old 09-19-2010, 05:24 PM   #12
cyberpine
cyberpine's Avatar
I bought the truck with all this after market stuff. Truthfully It was running great when I bought it, though I know the previous owner had just replaced the fuel filter.
To me, my problems started after I did an engine wash. I likely f***ed up the map sensor or something else.
By the way we already replaced the EGR valve as it had some kind of vacuum leak.
@RF. Thank You! That image is going in my project site right now!. I do need to learn how to troubleshoot the truck if I'm going to keep it.. though everybody I've talked to locally thinks TBI is a nightmare to figure out.. even if you are a so called mechanic.
Thanks guys.
JC (Cyberpine)
Old 09-19-2010, 05:41 PM   #13
rfmaster
rfmaster's Avatar
To me, my problems started after I did an engine wash. I likely f***ed up it up.
@rf. Thank You! That image is going in my project site right now!. I do need to learn how to troubleshoot the truck if I'm going to keep it.. though everybody I've talked to locally thinks TBI is a nightmare to figure out.. even if you are a so called mechanic.
Thanks guys.
JC - you welcome. A side note - MAP sensors are easily damaged by moisture. It is conceivable that when you washed engine bay some moisture got into MAP sensor. Unfortunately I am some 2600 miles to the west and I have a bunch of MAP sensors that I pulled from JY expeditions (as well as other stuff). Functionality of MAP sensor can verified with a hand-held vacuum pump and DVM. This test is a bit involved, perhaps I should put together a DIY test on the TBI swap thread. No fancy test equipment is requried. That is the beauty of TBI - it is a very simple EFI system.
The PO installed the best upgrade possible - I would keep it.
//RF
"The Beast"
Old 09-27-2010, 09:00 PM   #14
cyberpine
cyberpine's Avatar
Update: My mechanic found an old Camaro from around the same year in the junk yard and swapped out the Throttle body keeping the injectors. Though I'm yet to see it he's says it's running strong and no longer dies when you gas it. Before doing that, he tried swapping all the compentents discussed - no changes resulted from changing the MAP Sensor, TPS or IAC.
He says the computer on the truck is not original.
I'm not clear yet on exactly why, but he had to disconnect some temperture control sensor (?) to keep it from from idleing way too high. However, when he disconnects it the engine light comes on .. no other apparent consiquence yet. Would you guys know what part he might be talking about? Even with it disconnected, he's finding it to idle kind of high.
He's across town so I can't even see it until Wednesday.
Many Thanks!
JC (Cyberpine)
Old 09-28-2010, 08:11 AM   #15
RandyP
RandyP's Avatar
In your last photo, to the left of the waterneck (towards the passenger side), that's a temp sensor. Goes in the front of the intake right by the water neck.
I got a new fuel tank, new fuel pump, new pickup filter and tossed the old stock TBI on mine. Runs like a champ now. Can't wait to get the other tank done now.
Old 09-28-2010, 08:37 AM   #16
cyberpine
cyberpine's Avatar
22-V on the grid? I don't think my mechanic is able to tell if it's sending or not.
JC (Cyberpine)
Old 09-28-2010, 03:30 PM   #17
Hulk Will Smash
Hulk Will Smash's Avatar
These are great threads. I'm still sneaking up on my TBI on my '87 454. RF has been a HUGE help and the truck seems to run better everytime I make a change (still haven't replaced the connectors/pig tails, but hoping that will go within the next couple of weeks). Thanks guys and keep up the great informational posts.
I'm not going to let TBI beat me!
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 09-28-2010, 04:05 PM   #18
rfmaster
rfmaster's Avatar
Many Thanks!
Camaro used a slightly different ECM (1228746) than a truck (1227747). If you look at ECM module there is a service number printed on a label along with broadcast code. Broadcast code (BCC) is used to identify emission - drivetrain calibration information stored in ECM's EPROM. For sake of discussion early TBI Camaros and truck C/K ECM's share same circuit design except that Camaro also incorporates IAT (Inlet Air Temperature sensor) on ECM pin C12 and there are two additional control lines: a) Charcoal Canister Purge (CCP) on pin A3 and b) AIR diverter control valve on ECM pin C1. You can swap 305 TBI truck into 305 F-body and it should run without any issues (provided that the two use the same trany). Swapping Camaro ECM into truck will result in DTC 23 being set (with open circuit ECM input line is pulled high which corresponds to very cold temperature -40C! ECM will command higher idle if it sees very cold air). All of this can be fixed with a custom EPROM - but that's another story all together.
Yep - it works, just have to follow step by step approach in troubleshooting. And it's simple enough to work on.
//RF
"The Beast"
Old 10-01-2010, 12:13 PM   #19
cyberpine
cyberpine's Avatar
Guys - I do really appreciate all your valuable feedback.
I'll preface this by saying I'm clearly no mechanic. So it's going to seem like I'm wasting my time, money and space a bit.
Update: I got the truck back. The guy that helped me out with it is a good guy, but I'm not sure he had everything he needed to really solve the problem. Honestly, not sure he did much but to take wild stabs in the dark frankly.
He replaced a Holley Throttle Body with some factory TBI he found. He says the model number matches the OEM for my truck. He also told me the temp sensor (which is brand new and you guys pointed for me) is disconnected now and I learned so is the Map Sensor (which is a swap). He said and (I confirmed) , the truck will not run with either connected at this point. I have a bag with all my old parts.
The truck is running, but clearly things are not entirely right. That said, the truck has never run l or idled as well since I've had it this past year.
When I picked up the truck last night it was out of gas and it was dark, so when I would hit the gas it looks like the pump would suck air and choke. If I kept one foot on the accelerator and hit the gas it would feel pretty strong.So I had it towed home (AAA - It has no tag) and added fuel on the trip home. This morning, It started right up and drove it. It has not driven that well in months.
I uploaded a video of this test drive. I'm sorry, it's annoyingly bad with the camera focusing on the steering wheel and gauges for too long. But will give you a picture of how it's running.
I'd like to also go back and append to my original question, Would it be a terrible idea to mount a Carb on top of existing intake? I have a 3704 EdelBrock TBI intake. Even possible? Is there an adapter? too restrictive? What carb? This guy agreed to do the install cheap. I understand I can get rid of all that electrical/sensory and mysterious crap, but I will need to add an external fuel pump.
Many Thanks again for any ideas or suggestions!
JC (Cyberpine)
Old 10-01-2010, 12:51 PM   #20
68 TT
68 TT's Avatar
...I'd like to also go back and append to my original question, Would it be a terrible idea to mount a Carb on top of existing intake? I have a 3704 EdelBrock TBI intake. Even possible? Is there an adapter? too restrictive? What carb? This guy agreed to do the install cheap. I understand I can get rid of all that electrical/sensory and mysterious crap, but I will need to add an external fuel pump.
The Edelbrock TBI intake sucks and adding a carb adapter to it will only make it worse if you could even find an adapter to put a carb onto it.
If you are dead set on going to a carburetor I would get a new carb intake for the center bolt heads. You may be able to find a used one but I don't believe Chevy made very many of them. The only one I can think of is the 87 & 88 Monte Carlo & El Camino that were still running Q-Jet carburetors when everybody else went to TBI. There are aftermarket ones out there but aren't very common as a used item.
Old 10-01-2010, 10:23 PM   #21
DBLSPRT68
DBLSPRT68's Avatar
Subscribed! I have a 454 TBI I will have to figure out the rough idle on soon.... Good info here!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 10-02-2010, 02:04 AM   #22
rfmaster
rfmaster's Avatar
JC
1) That 'mechanic' is a hack at best, but least he installed some different parts to see what works, what does not. Stay away from him - he has no clue how TBI operates.
2) By disconnecting coolant temperature sensor (CTS) ECM sees high CTS voltage which is equivalent to very cold temperature -40C. At -40C ECM will call for very rich mixture - this why you feel the power from engine.
3) By disconnecting MAP sensor ECM is forced into a limp mode (SES light is on continuously) Without MAP sensor input ECM uses TPS as its only source of engine load information available. It's ability to control fuel delivery is very limited.
4) TBI camaros were equipped with similar LO3 engines. So, if he really pooled TB unit from camaro it should have correct size injectors -2x 50lb-Hr which is adequate for a stock 305. (I would verify this soon, but its ok for now)
5) The hissing noise you are hearing is probably (It tough to be certain without being there) from a fully open, stuck IAC. This would explain very high idle 1100 to 1200 RPM.
6) I am also guessing that your 'mechanic' also screwed around with base timing by moving from 0 deg to 20. In limp mode ECM fixes timing to a constant value. He probably over advanced timing to get it to run without MAP and the moment MAP is reconnected ECM tries to control timing by advancing as it normally would which way too much - ECM has no idea that base timing is way off - killing engine in the process.
Analysis
a) Fuel system appears to deliver enough fuel.
b) Sensors MAP, TPS, CTS - remain questionable, but appear functional
c) IAC - operational - should be verified.
Things to do
1) Reconnect all sensors plug CTS back in, reconnect MAP, make sure all other hoses, plugs are fully plugged in.
2) Perform POST = Power on self test. Move ignition key from Off to Acc to Run position - SES light should go from Solid ON - blink off - solid ON (do not start engine) Fuel pump should turn on for about 2-3 seconds and shut off. This would indicate that ECM is operating normally by being able to read EPROM contents. - Turn off ignition
3) Locate ALDL connector - it is located just under steering column. It looks like this:
4) Pulling DTC codes with a simple paper clip. Insert paper clip into socket pins A & B (usually upper right corner) shorting the two togther. Turn ignition into run position, but do not start engine.
Observe SES light. If there are no DTC codes set SES will blink code 12 three times. If there are DTC codes set each will be flashed 3 times in ascending order, pause followed by the same sequence again. So, for example of CTS and MAP are disconnected DTC 15 and 33 will be set:
12...12...12....15...15...15....33...33...33 12 12 12 15 15 15 33 33 33 and so on.
At the same time ECM will command IAC to fully closed position, which you can verify by observing IAC pentacle closing idle air passage - from the top looking down (sorry, I do not have photo handy right now - will post tomorrow)
Perform this simple test and post what you see (and please stay away from that 'mechanic') .
//RF
"The Beast"
Old 10-02-2010, 10:05 AM   #23
cyberpine
cyberpine's Avatar
Thanks RF,
Sensors back on. I do hear the gas pump or something turning on.
I think I'm reading 15 and 34? I might need to do it again as there might be more codes. All of that and see how it runs with sensors on.
JC (Cyberpine)
Old 10-05-2010, 01:22 PM   #24
cyberpine
cyberpine's Avatar
The last mechanic that worked on the truck told me I have 400 turbo and he based that on the distinctive pan shape. I don't have a good pic to confirm that , and really not sure otherwise how to confirm what transmission I have. I do wonder if my base factory 305 with came with that transmission. He says there was no port on that transmission to connect to the TB.
Will try to do these two tomorrow. I never noticed any moving parts int he in the IAC.
Should be interesting as I've never adjusted idle RPM on this truck either.
from your earlier post:
1) Lets clear all those DTC codes as they were artificially induced. This is easily done (engine off) by disconnecting negative Battery terminal for about 30 seconds. ECM will clear its fault memory from these codes until it sees subsequent fault conditions.
2) After clearing ECM fault memory we need to make sure that IAC (Idle air) is correctly reset and knows where it is. The procedure is very simple:
a) Place ECM into diagnostic mode by shorting pins A&B - this will force ECM to command IAC to continuously move into fully close position.
b) Without starting engine, ignition in run position you should be able to hear clicking noise from IAC being jammed into full close position. You can see IAC pentacle fully closing idle air passage in the TB (10 o'clock).
c) Remove the connector (It is 4 wire arranged in box) from the IAC and start engine while monitoring idle speed. Minimum idle speed for a stock engine should be around 450 rpm (can be adjusted).
d) Shut of engine, remove A+B jumper, re-connect IAC connector. Restart engine - idle should be around 600-650 RPM. Provided that base timing is correctly set and there are no vacuum leaks.
JC (Cyberpine)
Old 10-05-2010, 02:17 PM   #25
rfmaster
rfmaster's Avatar
JC
TH-400 trany pan looks like a state of Texas. 700R4 pan is a square shaped pan.
http://www.nastyz28.com/chevy-transm...tification.php
//RF
"The Beast"
