Old 06-19-2018, 01:36 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
High Torque Mini Starters
My stock starter is going out and I would like to try something different, so I was researching mini starters, came across this guy:
Powermaster Ultra Torque Starters 9400
https://www.summitracing.com/parts/pwm-9400
I know its a powerful starter for a Gen 1 / 350 running 9.87 compression. Its a mini made out of aluminum, with adjustable mount plate. I need the adjustable mount plate because I'm running a SM465 with stock bell housing.
My issue with stock High torque starters is when they heat up, they dragggg. I have done all the suggested fixes, starter wrapped in thermal tape, aluminum heat shield, new H/D battery cables wrapped in thermal tape. Running Oddessy battery (always)...
Blazer has been sitting for a few weeks, went to start it yesterday, starter dragged a little, thought it might be battery, ran it for a while, check voltage, good, ran for about 10 miles down the road. Came back, shut if off restart, barley turn over, put big battery charger on it, no effect, drag and would not fire. Battery is good under load test. Seems like when it heats up, it dies. Went out this morning, fired up no problem. So, just looking at different options and opinions.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 06-19-2018, 01:56 PM   #2
Getter-Done
Getter-Done's Avatar
Re: High Torque Mini Starters
I have had same problem with my 350’s.
I don’t know if I would ever put anything but a high torque starter on my Chevy’s
84 Chevy K-20
Old 06-19-2018, 04:06 PM   #3
DieselSJ
I've run the Summit brand high-torque mini starters on a few vehicles. Have one currently on the 454 in the dually. Never had a heat soak issue with them, even when tucked in behind the headers on a 72 El Camino.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 06-20-2018, 12:04 AM   #4
AcampoDave
AcampoDave's Avatar
I've run a Jegs mini for years, never misses a beat.
AcampoDave is offline   Reply With Quote
Old 06-20-2018, 09:14 AM   #5
Dead Parrot
Possible the starter brushes are shot. Less then a $10 fix the last time mine went out. And you don't have to deal with a new shim setup.
Dead Parrot is offline   Reply With Quote
Old 06-20-2018, 11:19 AM   #6
SunSoaked
SunSoaked's Avatar
Try the remote "Ford" type solenoid. I went thru the heatsoak dilemma years ago, and like you, tried everything. The remote solenoid fixed it once and for all. I just changed my current 85 k20 over. It sure makes installing/removing the starter easy by getting those cables out of the way. I'm in S.Arizona- summer temps 110+, headers and high compression.
SunSoaked is offline   Reply With Quote
Old 06-20-2018, 11:41 AM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Do you have any pictures of this set up? Sounds interesting.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 06-20-2018, 12:28 PM   #8
SunSoaked
SunSoaked's Avatar
https://www.summitracing.com/search?...sre-brand-_-ad
Old 06-20-2018, 12:30 PM   #9
DieselSJ
Pretty easy to do. I have all my GM vehicles set up that way.
You need to pull all the wires off your starter.
-You will have a heavy battery cable and a 10ga wire or two on the same heavy stud. Those will all still stay together on the new setup.
-You will also have a lighter gauge wire going to the back of the solenoid on the starter.
Mount the Ford solenoid somewhere convenient.
All of the wires that were on the heavy stud on the starter will go to one of the heavy lugs on the solenoid. The lighter gauge wire goes to the "S" terminal on the solenoid. You need to add one more heavy wire from the other heavy stud on the solenoid to the heavy stud on the starter. Final piece is make a 10ga jumper to go from the heavy stud on the starter to the smaller stud where the lighter gauge wire was.
This does a few things -
- You no longer have electrically energized wires running to the starter all the time.
- You are no longer pushing 10-15 amps through your ignition switch to engage the starter. The Ford uses less than 3A.
- You get more power to the solenoid on the starter because you are not running it through 15 feet of wire and your ignition switch.
Old 06-20-2018, 12:37 PM   #10
SunSoaked
SunSoaked's Avatar
Most importantly is that it gets the solenoid away from the engine heat, especially if you're running headers. The heat is what causes the solenoid to drag due to thermal expansion.
Old 06-20-2018, 01:22 PM   #11
I’m also running a high torque on my K30 big block 454 with headers, works fine.
Old 06-20-2018, 02:05 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I guess I've been lucky... I've driven Chevy Cars and Trucks my whole life (44 years) and never experienced heat soak on a starter. I have also installed headers on every vehicle I've ever owned.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-21-2018, 04:13 PM   #13
mattfranklin
mattfranklin's Avatar
And that will give you a chance to inspect and clean up the commutator, too.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 06-21-2018, 06:24 PM   #14
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Gary
Gary, first time I've dealt with this. I'm not running headers, just straight dump 2.5 ram horns. I'm going to have the starter rebuilt by a shop that I have used for years. Put it back on, go from there. Got a good direction, I appreciate everyone's input, hope this helps other folks too.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 06-21-2018, 09:47 PM   #15
Mike C
Mike C's Avatar
My '86 K30 with the 454 and headers heat soaks in a bad way. It will be getting a gear reduction starter at some point.
I put a Denso style CVR starter on my Jimmy 20 years ago like in your picture for the same reason, the cast iron bellhousing with it's block mount starter. I would not hesitate to do the same again.
GM quit running the old style starts and I have as well. As soon as one takes a dump I usually replace it with a brand new AC Delco gear reduction starter off Rock Auto for about $75. But the cast iron bell makes the non-supported nose type an easier fit.
The TuffStuff is only $151 at Jegs... My Jimmy has a 9.8:1 327 in it an the CVR has been great.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-23-2018, 10:51 AM   #16
GASoline71
GASoline71's Avatar
10-4! I have helped other cats install the remote solenoid, because they too were experiencing the heat soak problem. Again... no idear why I've never had this issue for as long as I've owned and drove GM cars and trucks.
Gary
Old 06-23-2018, 08:17 PM   #17
franken
Obviously if adding another solenoid resolved the issue, it was never heat soak because the heat hasn't changed a bit. The wiring was changed, which is the actual issue. Adding more components to a system that someone can't troubleshoot is not the correct answer.
franken is offline   Reply With Quote
Old 06-25-2018, 02:40 PM   #18
DieselSJ
Yes, heat soak was the issue. The solenoid on the starter gets heat soaked and it can't pull enough current through the ignition switch circuit. Going to the Ford solenoid allows for it to basically pull as much current as it needs and that helps to overcome the issue. Not to mention you also get all of your main electrical feed and charging wires up out of that hot environment which helps everything.
Old 06-25-2018, 03:05 PM   #19
SunSoaked
SunSoaked's Avatar
Exactly. Hard to argue with success.
Old 06-25-2018, 06:17 PM   #20
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I understand what your saying, I installed a new MH engine electrical harness, firewall forward when I pulled engine for rebuild. I ordered a Painless Performance Remote Starter Solenoids 30203. I wanted to look at the wiring diagram to see how it works with GM starter.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 06-26-2018, 06:48 PM   #21
DieselSJ
Old 06-28-2018, 10:28 PM   #22
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Got the Painless Performance Remote Starter Solenoids 30203 kit. Looked at the wiring diagram, makes sense. Rebuild starter, install the solenoid kit. Its time for new Battery cables. Ill have to hand make those to fit. I will get some picture once its done.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 06-30-2018, 01:53 AM   #23
mr48chev
mr48chev's Avatar
Gary
You sir lead a charmed live as I have fought the heat soak thing on my 77 Dualie with a 454 since I bought the truck and think that was an issue before that. A Mr Gasket heat shield, Ford remote solenoid and larger cables seem to have done a pretty reasonable job of curing the problem.
On the gear reduction starter thing. Later GM rigs run gear reduction starters that are bolt on for earlier engines.
My ongoing truck projects:
Old 06-30-2018, 04:41 PM   #24
franken
You didn't understand what I meant, and don't know what the real issue is or how to correctly solve it.
Old 06-30-2018, 08:20 PM   #25
dave`12
dave`12's Avatar
I had this problem. Here is a quote from Vettevet who helped me concerning the ford solenoid fix (and he is the best here).
"If the starter turns over it indicates that the solenoid is not heat soaked or it probably wouldn't even click.If you are getting a slow roll all the time when the engine is warm then the Ford solenoid is most likely not going to help."
A high torque mini starter fixed it for me.
Here is the link to my thread. Lots of good info here.
http://www.67-72chevytrucks.com/vboa...d.php?t=729029
dave`12 is offline   Reply With Quote
