11-12-2017, 07:11 PM | #1 |
How much is too much (lower ball joint interferance)
I have been working on replacing all control arm bushings and ball joints on my G body front clip. Everything was going fine until I tried to install the lower ball joint. It has .020" interferance and it just seams like it is too tight to go in the hole. I bought Moog parts thinking they would be good. I think .010" would be plenty for interferance fit. I may run a flapper wheel in the hole to loosen up a touch. What do you guys think?
Thanks Mac |
11-12-2017, 08:09 PM | #2 |
Re: How much is too much (lower ball joint interferance)
I can't comment on what the proper interface should be I experienced what you're experiencing. I also used all Moog parts to redo the front end on my S10 chassis swap. I had the control arms out when I went to put in the lower ball joints and they were a mother to get started and fully pressed in. I was using a ball joint press which looks like a big beefy u-clamp. I could only get them in so far with the control arms off the chassis with an impact. I had to put the control arm back on and use a long breaker bar to get the joints fully seated.
11-12-2017, 08:21 PM | #3 |
Wow. I went to parts store and measured a Moog and a cheapie and they both measured the same as mine. I need a press!! Thanks.
Mac |
11-12-2017, 09:33 PM | #4 |
Hollister Road Co.
The aftermarket are larger because you press in and out the originals and that stretches the hole somewhat. .020 is to make sure you have a tight fit if the hole is stretched. You always press them in, you can knock them out with a hammer or put them in with a hammer your a frame is bad
11-12-2017, 11:28 PM | #5 |
Always sand/grind on the item that easiest/cheapest to replace. IOW, grind on the bushing, not the control arm - grind on the tie rod end, not the spindle steering arm. I learned this lesson by having to buy new control arms.
11-13-2017, 12:16 AM | #6 |
I got it in, the reason I was concerned was the metal was starting to split where it is rolled out from the stamping. That made me want to research a little.
Thanks Mac |
11-13-2017, 04:31 AM | #7 |
What A arms are you putting the ball joints in? When I was doing front end work I used to run into some GM lower A arms that were a bit sloppy and wouldn't hold a ball joint tight. I took a center punch and staked some and replaced others. Even tack welded a couple of ball joints in place when the owner didn't want to spend extra money on them.
That said, I wouldn't grind on them to get them to fit.
11-13-2017, 09:34 AM | #8 |
1979 stock G Body A arms.
11-13-2017, 05:09 PM | #9 |
Are you using a ball joint press or ?
11-13-2017, 09:25 PM | #10 |
I used the BFH and some anti-seize and a piece of pipe as a driver, didn't have any fancy tool at the time. However I did go buy a press off CL for $75. For next time.
You could always pick up a press off CL and just resale it when your done, they seem to sell quick. They do sell oversized ball joints, for the sloppy A arms ,I've never ran into the need to use one yet |
11-13-2017, 10:25 PM | #11 |
Warrior and 48, I used the BFH method also. Took the other side apart tonight but didn't try to drive that one in yet. I might drop it off at my mechanic's shop tomorrow and see if he will press it in for me.
Mac |
