03-25-2019, 03:34 PM | #1 |
Burb Frame vs. Truck Frame
Are burb frames wider in the rear? I am trying to install a No Limit shock relocation kit on my burb and the shocks are angled in toward the center of the truck like the top mount is too far out. The only explanation I have is that the frame is wider on the burb and the mounts are designed on a truck frame.
03-25-2019, 11:58 PM | #2 |
60-66 Nut
Re: Burb Frame vs. Truck Frame
The '63-'66 C10 Suburban/Panel frames are the same width as the '63-'66 C10,20 pickup frames. The '60-'62 C10 Suburban/Panel frames are the same width as the '60-'62 C10,20 pickup frames. The '60-'62 frames are wider in the rear than the '63-'66 frames.
03-26-2019, 09:57 AM | #3 |
Thanks, Captain. I guess there is some other reason for the shock mis-alignment.
03-26-2019, 10:38 PM | #4 |
I used then on my 62 fleetside and I had to trim them to 1" wide and they lined up fine.
03-29-2019, 10:59 AM | #5 |
03-29-2019, 03:41 PM | #6 |
I trimmed the upper mount to 1" wide and it lined up with the bottom shock mount.
03-29-2019, 04:55 PM | #7 |
