Old 11-19-2019, 02:33 PM   #1
Shifty One
Shifty One's Avatar
Re-painting the hubcaps question
1987 V20, are the colors (black, and gold bowtie) matte, gloss, or somewhere in between? Mine are to far gone to tell.
Shifty One is online now   Reply With Quote
Old 11-20-2019, 03:09 PM   #2
Shifty One
Shifty One's Avatar
Re: Re-painting the hubcaps question
Old 11-20-2019, 05:15 PM   #3
bhc41051
bhc41051's Avatar
I don't believe gloss is right, the gold is Ochre Ditzler 2323, and the black is similar to the black on the side moldings. Just my humble opinion.
bhc41051 is offline   Reply With Quote
Old 11-20-2019, 06:07 PM   #4
Shifty One
Shifty One's Avatar
Thanks BHC!
Old 11-20-2019, 07:09 PM   #5
SCOTI
SCOTI's Avatar
I used VHT Black Satin Epoxy on the ones I've done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-21-2019, 10:36 AM   #6
Shifty One
Shifty One's Avatar
OK, SCOTI, I sell that stuff, I'll give 'er a look.
Old 11-21-2019, 10:47 AM   #7
SCOTI
SCOTI's Avatar
One warning (it's in the instructions as well...), follow the re-coating timeline if you use it. If you add delayed additional coats too early, the fresh coat can cause a reaction w/the previous coat. Other than that, I like the stuff. It has a very consistent 'sheen'.
It's not the best quality pic but the cap on the left is OE; the right one was repainted.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 11:48 AM   #8
Shifty One
Shifty One's Avatar
Dang SCOTI, even the one that "needed" paint is 150% better than mine...
Old 11-21-2019, 11:49 AM   #9
Shifty One
Shifty One's Avatar
BTW, I bet masking off ain't no fun...
Old 11-21-2019, 11:59 AM   #10
SCOTI
SCOTI's Avatar
I used a circle cardboard template for the center & just masked the edges.
For the raised portion of the caps, I don't tape to a paint line. I just tape to keep the bulk mass from getting overspray. As I did each coat, I would take a shop towel (I like use an old worn-out t-shirt for stuff like this), pull it tightly to my finger-tip, dip it in reducer, & carefully wipe the edge where the 'color' should stop.
You can do the clean-up @ the end of the final coat or after it's completely dried. I do it between coats because it's much easier to get the overspray off vs. once it's sat overnight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2019, 12:34 PM   #11
Shifty One
Shifty One's Avatar
Interesting. I considered using liquid masking tape....I may hand-paint the bowtie (going to change it to blue, similar to the early 60's 'caps).
