02-25-2019, 04:01 PM | #26 |
Post Whore
Re: Rusty Roof Best Approach?
I'd agree with Robert...I'd blast that thing ...then you'll know what youve got left to work with...
I've got a buddy that swears by por15...but he said it'll only stick to rusty metal...comes off clean shiny metal...I've never used the stuff though...and probably never will...
02-25-2019, 05:32 PM | #27 | |
Thanks for the speedy reply. What should I expect from the areas that still have some pitting after I clean/blast thoroughly? Will those areas definitely rust again in the future no matter what I do? Or, if cleaned well enough (to shiny metal) and covered with a good epoxy primer as you suggest, will not rust/deteriorate further?
02-25-2019, 05:36 PM | #28 |
Post Whore
The blasting will reveal any rust issues you have...cut out and replace the rotted stuff....
If you blast it to bare metal and spray it with epoxy primer you shouldn't have any more issues...
02-25-2019, 05:41 PM | #29 |
I agree also, repair the rust, no need to remove the inner roof panel. I just did this repair, before I put the new roof on (after primer) I sprayed cavity wax down the A & B pillars and along the rear of the cab. the driver's A pillar has an access hole already, I drilled a hole for the passenger side.
02-25-2019, 05:58 PM | #30 |
Can you Take a close up picture of the hole in the A pillar on the driver side??? I tried to locate it with a pull wire but wasn't sure were it was.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-25-2019, 09:39 PM | #31 |
Sure, here's the best I got. The hole has a rolled edge on the bottom side that might make it more difficult to snake a wire through.
07-23-2019, 10:05 PM | #32 |
Got distracted with my other project (64 Nova Wagon) for a while and finally getting back to this. This might be more trouble than it is worth, but anyone want a roof? The first one I ordered from LMC was dented. Customer service was great and they sent me a replacement and told me to trash the bent one. I hate to just throw it out. The bend is not that bad (see picture below) and could probably be worked out easily by someone with the right skills. Anyway, if you are interested, shoot me a PM. I will donate the roof, but you would have to pay for shipping. The box is huge and I think LMC charged me about $150 to ship, but I can imagine it could cost as much as $200 to ship, depending on location. I can give you the dimensions and you can shop around for best price.
08-06-2019, 11:11 PM | #33 | |
11-08-2019, 03:22 PM | #34 | |
11-10-2019, 06:47 AM | #35 |
Really appreciate the time that has gone into this thread. I'm at the point of evaluating my rust damage and plan of attack. The front roof area along with windshield pinchweld are top of the list for me. Figure I might as well start at the top and work my way down. Just as the rust did.
1972 C/10 LWB - Mine 1964 C/10 LWB - My Dad's Instagram: Mike_The_Grad |
11-10-2019, 11:35 PM | #36 | |
02-28-2020, 09:30 PM | #37 |
Just curious about the cavity spray you used. Is that better than those internal frame coating sprays sold by Eastwood like this?
https://www.eastwood.com/eastwood-in...z-aerosol.html I am getting close to closing mine up and want to spray something protective down there before closing it up. I like the spray nozzle attached to the tube so u can get far down. I have seen some cavity wax spray cans with that tube tip spray setup too so I think my question is more directly related to the difference between using a wax spray and paint spray in the pillar cavity. Which is best? Thanks! |
03-03-2020, 11:07 PM | #38 |
Hi guys. After a ton of scraping, grinding, cutting, welding, cleaning, and painting, I am close to the point where the new outer roof can go on. The original plan was to glue the roof down (as was done by some others on this forum) but it looks like it might not give the best fit. Welding it on will give me an opportunity to manipulate the fit between welds and may get it to fit together better.
Can some of the sheet metal gurus chime in with their thoughts? I included a few photos below. My two major fitment issues are: 1) Gap wide in one section (see green arrow in second photo below) 2) Roof sitting lower than rear edge of cab (red arrow in second photo below) One thing to note is that when I cut the old roof off I accidentally cut out the rear inside lip that would be needed if I were gluing the roof. So I fabricated a lip and welded on one small section to test. I am not liking how the added lip interacts with the new roof and it seems like it might be more trouble than it is worth. Again, if I just weld that seem then the underlying lip is not required. Please let me know what you all think. Thanks. |
03-04-2020, 12:11 AM | #39 |
Post Whore
Your gonna need your fit to be really good..if you had access to the backside ,you could back it with copper to help prevent burn thru while welding...but I'm fairly sure you dont..so you'll have to rely on having access to one side only..this also eliminates you being able to hammer and dolley your welds...
Mp&c would be whose advice I would take...whatever it is.. but if it were me I'd ad some metal strips to the roof edge to eliminate the gap...you need a good small gap for welding..and some very slow welding...magnets will help hold up the roof where its low...
03-05-2020, 10:35 PM | #40 |
I’d check with Dewayne at Nsane Hot Rodz. He’s used about any and all panels made for these trucks, he should be able to steer you in the right direction
Robert |
03-08-2020, 08:54 PM | #41 |
Do not use black moisture cured urethane's. These coatings are concrete primer with black pigment. When God created permanent rust sealer's it only came in one color silver. The resin blocks the moisture, the aluminum flake in layers two coats blocks the oxygen. This is the most powerful of your industrial primers. Seal the roof with the permanent rust sealer and followed up with epoxy surfacer. I've been doing it this way for years with great results
03-12-2020, 10:32 AM | #42 | |
Thanks for your reply lupo. Can you give an example (product name or link) of a rust sealer like you mentioned below? Thanks.
03-12-2020, 11:07 AM | #43 |
Permanent rust sealer's that use a primer pigment are available from Mastercoat, this type of pigment is important as the coating will dry toothy to promote paint adhesion. I'm not sure what type of pigment is used in Rust bullet. Superior coatings has a product called rust lock but am not sure if they sell to the public. There is a video on YouTube titled POR 15 – KBS – chassis saver – SPI epoxy Mastercoat salt fog test. Who went the furthest?
04-20-2020, 09:57 PM | #44 |
Well, FINALLY got the new roof (and new drip rails) fit nicely an welded into position! I ended up getting rid of the lip I fabricated and just welded the back seam (see pics below). Tons of grinding, shaping, banging, etc. to get all the parts to fit well. Some of the metal had to be moved as welds were made. Pretty happy with the final look. Still some work to do.
Wondering if I need to fully weld the rear seam or not. Currently, I have a welds at least every 4 inches, closer in some areas. Should be pretty structurally sound as-is. What would you guys do? Thanks! |
04-21-2020, 05:01 PM | #45 |
Post Whore
weld it solid...that's what id do
04-21-2020, 05:57 PM | #46 |
Take your time and weld all the way across. If you dont weld all the way across you will wind up with cracks in your paint work later. Alternate from side side so you don't create warpage
Thread Tools | |
Display Modes | |
