10-24-2019, 11:21 AM | #1 |
Cab and door body work In order
I am reskining both my doors and they need some work on the Inside. Should all that work be competed before I do the cab so when I do the rockers they can be aligned with the doors?
10-24-2019, 11:39 AM | #2 |
Re: Cab and door body work In order
Also a guy I was talking with said he sandblasts cabs. Seems to me this might warp stuff. Is that a common practice?
10-24-2019, 05:14 PM | #3 |
Get your doors dun first but I would check the skin fit with your opening as you go then do rockers
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
10-24-2019, 05:27 PM | #4 |
Sandblasting is a good way to prep your cab but if you don’t know what you’re doing its also a good way to screw it up you have to be carful with the large panels the rest of the cab you don’t have any problem with
10-24-2019, 05:30 PM | #5 |
Ok. My cab will be getting a new floor put in it so I assume it should be the very 1st step. Then do the doors and then do the rest of the bottom of the cab
11-16-2019, 08:25 PM | #6 |
Do your doors first then the outer rockers. I did my rockers first and now they are off about 1/4". I have to cut them out a reset them so they fit right. Lesson learned.
Brad handshoe |
Thread Tools | |
Display Modes | |
