Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-09-2016, 11:24 AM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
Can this be fixed without filler?
It is possible to get behind this dent and push it back out? I really do not want to use filler in this area as I think it would not hold. Any advice would be appreciated. TIA.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
2015 Silverado 1500 LS 4.3/6L80/3.23
70STOVEBOLT is offline   Reply With Quote
Old 11-09-2016, 04:04 PM   #2
cg285
Re: Can this be fixed without filler?
i assume you mean the gap in the jamb? pic not clear to me. if so i would pull it.
cg285 is offline   Reply With Quote
Old 11-09-2016, 04:10 PM   #3
70STOVEBOLT
Yes, the jamb. The leading edge has been pushed in about a 1/4". I was going to remove the seat and tank and see if I could get behind there, but I am not sure I can.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 11-09-2016, 07:10 PM   #4
tinydb84
tinydb84's Avatar
You can use a spot gun. You could metal finish it if you have the skill and time. It would be easier to work out as much as you can with a spot gun/hammer/dolly then do a skim pass of filler.
David
Instagram: myfabguy
Old 11-09-2016, 09:46 PM   #5
hugger6933
lf you don't have a spot gun like suggested above, you could weld [tack weld] a strip of scrap on there and pull it with a come-a-long and it should pull pretty easy. Also You need not worry about filler there if prepped right you will be fine.
hugger6933 is offline   Reply With Quote
Old 11-10-2016, 07:28 AM   #6
dracko
dracko's Avatar
You could also weld some tig filler rod on there to fill the void and then grind smooth, so the actual edge is at least steel
dracko is offline   Reply With Quote
Old 11-30-2016, 03:43 AM   #7
racin69z
racin69z's Avatar
I welded along that area evening up the door gaps, and I think I angered some deep down 40 year old rust that was hanging out between the spot welds. That's the only place that has started to rust on my truck.
I would be cautious welding in that area.
Lynn
racin69z is offline   Reply With Quote
Old 11-30-2016, 11:41 AM   #8
70STOVEBOLT
I am planning on using a hammer and dolly, but if I have to weld it, then that is what I will do. I do not have any welding equipment so I will have to hire it done.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
Old 11-30-2016, 06:01 PM   #9
Indian113
Indian113's Avatar
Our local Rent tool place has welders you can rent. Otherwise I hired a portable welder to do some work once it wasn't to high of a price
Indian113 is offline   Reply With Quote
Old 12-18-2016, 07:44 AM   #10
Grumpy old man
Grumpy old man's Avatar
Use a straight edge to determine how much of the jam needs to come forward ,
Using your cut off wheel cut 1"in from the edge to 1/2" past the length you want to move forward
using a stud gun pin ang pull forward from the door jam that section lightly until your happy with the fit . Tack weld patch panel in place and work as usual.
Most all doors have a distortion in that area from the manufactor processing of the door panel , you can add multiple tacks to build up the area or tack some rod in place and grind to fit , this area gets overlooked many time even on high end truck builds . Have fun , but remember it's only metal ...
Grumpy old man is offline   Reply With Quote
Old 01-08-2017, 01:22 PM   #11
elf w/capital T
Yes, get some round stock, got mine at lowes... think it was 1/8th thick, welded in, oshpo then painted...well not painted yet... weld stuff dont use that bondo as less as you can, ish cracks and ruins everything
elf w/capital T is offline   Reply With Quote
Old 01-08-2017, 01:23 PM   #12
elf w/capital T
Keep us posted on how it turned out!
Old 01-08-2017, 03:15 PM   #13
70STOVEBOLT
elf, it will be a while before I get to this, but I will post the results and the method of repair.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Coming soon: EFI
