Old 09-14-2018, 12:19 AM   #1
nigelbenchoff
Back up lights?
Hello I’m fairly new to these trucks and no where near a mechanic. So I bought a ‘67 GMC SWB that had the original three on the tree moved to the floor. While attempting to get it inspected the reverse lights don’t engage. How do I correct the wiring to the new shifter to make the truck legal?
nigelbenchoff is offline   Reply With Quote
Old 09-14-2018, 12:49 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Back up lights?
Do you know what brand shifter it has ? Hurst makes a separate switch mounted to the shifter body .
https://www.summitracing.com/parts/h...SABEgKicPD_BwE
Old 09-14-2018, 01:02 AM   #3
nigelbenchoff
Re: Back up lights?
Yessir, it’s a hurst shifter
Old 09-14-2018, 06:38 AM   #4
Redneck Rydes
Redneck Rydes's Avatar
Re: Back up lights?
It might be easier to just put them an a toggle switch under the dash,just run the hot wires to a switch and voila.
Redneck Rydes is offline   Reply With Quote
Old 09-15-2018, 03:42 PM   #5
builtbyKane
builtbyKane's Avatar
Re: Back up lights?
lokar makes a few different reverse light switches. I'm running one now that once adjusted correctly works perfect.
builtbyKane is offline   Reply With Quote
1967 gmc, reverse lights, shifter relocation
