Old 09-22-2017, 10:58 PM   #1
1968aj
ROAD SALT victim in Texas
I thought i had found the truck i was looking for. A 72 cheyenne super.it was a unmolested 1 owner solid blue with wood bed floor.i drove 75 miles to see it. The cab looked great inside and it fired right up. Everything worked on it.well; then i noticed a dealer emblem from minnesota . Looked under the truck and never have i seen this in texas. Everthing was rusted. You could stick your finger through the trailing arms and the frame was almost that bad.anyway the asking price was quickly cut in half but i couldnt tell him i would not give $500 for it for parts. I did not take pictures. Why do they use this stuff on roads? There has to be a better way. Anyway the search goes on.
1968aj is offline   Reply With Quote
Old 09-22-2017, 11:54 PM   #2
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: ROAD SALT victim in Texas
Some of those "salt state" trucks can be pretty rough.
I've seen a few.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 09-23-2017, 12:24 AM   #3
In The Ten Ring
Wow, life in TX must be pretty grand....
My dad bought my truck new off the lot in 1972 and drove it as a work truck for about 10 years, most of the time in winter he rode to and from work with a friend. My truck has pretty bad rust.
Front end was in bad shape. Inner fenders, passenger out fender, one grill bracket, core support: trashed. Junk. Rusted beyond repair.
Cab: holes in floor. Rockers: yuck.
Doors: bondo babies.
Rear fenders: bondo babies again.
Frame seems solid.
At least one A arm is rusted through.
And that was just 10 years of very limited use in winter as it is a two wheel drive and according to my dad "no matter what you did---lower tire pressure, put in bed load, use chains---you go backwards on hills."
These trucks were neither designed nor protected against rust. Salt is evil (and it is, for the environment) so gravel should be used.
In The Ten Ring is offline   Reply With Quote
Old 09-23-2017, 01:16 AM   #4
mike16
we are spoiled here in SE Arizona
mike16 is offline   Reply With Quote
Old 09-23-2017, 06:55 AM   #5
72 tigger
72 tigger's Avatar
That's why most of the trucks I've restored are from TX & most of the trucks I've parted are from IN. That is one advantage to living in the salt region- lots of donors available with good trim and interior pieces
72 tigger is offline   Reply With Quote
Old 09-23-2017, 09:01 AM   #6
1968aj
sounds like I should start buying up all these rolling frames I have been seeing. frames are plentiful and cheap. I gave away complete 72 frame cab and bed to the local scrapper.wish I would have kept it now.
Old 09-23-2017, 01:00 PM   #7
In The Ten Ring
Probably wouldn't be a bad idea. Buy what's cheap now and hope it gets more valuable later.
If I had the storage space, I'd buy an extra frame or two.
Old 09-23-2017, 05:33 PM   #8
C10 - C90 Bill
If it's '72 and older, I save everything, lol.
GMC 9500 Fan
Detroit Diesel Fan
Old 09-23-2017, 05:44 PM   #9
1968aj
I do to now. a few years ago I was getting out of 67-72. I sold a running 72 highlander and a bed full of parts for $500. I gave away a 72 super parts truck. now here I go again.
Old 09-23-2017, 05:59 PM   #10
Curtb1971
Curtb1971's Avatar
Same, it's funny how when I was 18 all the original stuff on my truck wasn't cool like the perfect hub caps, camper mirrors, dealer bumper, emissions equipment and even a blue steering wheel made it to the trash. Ah years later I'm like wow I just hucked all those parts! I figure now someone or even me has a use for even the smallest things. So while I have the room might as well hang on to the old stuff because you never know what you'll drag home next.
Curtb1971 is offline   Reply With Quote
Old 09-23-2017, 09:36 PM   #11
too much stuff
Roadtrip!
too much stuff's Avatar
And welcome to my world. Remember what dealer emblem was on it?
Get an AZ body and a MN interior and you will have a pretty decent truck!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-24-2017, 12:12 AM   #12
custom10nut
custom10nut's Avatar
Salt and the "Rust Moths" are the reason ANY classic (72 and older) vehicle from down south (or out west) are so valuable.
I grew up in Michigan, home of the Worlds Largest Salt Mine, (under the Detroit area) where your car loan was guarenteed to outlast the undercarriage of your vehicle.
I've bee in the south for over thirty years now, and would walk many miles rather than drive my truck on salty roads.
custom10nut is offline   Reply With Quote
Old 09-24-2017, 01:25 AM   #13
tmontg01
tmontg01's Avatar
We are!
tmontg01 is offline   Reply With Quote
