06-29-2017, 09:01 PM | #51 |
Re: Post your pics of 60-66 BIG BLOCK only trucks / engines
I have the exact setup now and I to figure that one out. Did you have to notch the frame? |
06-30-2017, 08:12 AM | #52 | |
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
06-30-2017, 02:50 PM | #53 |
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
06-30-2017, 08:58 PM | #54 |
Has anyone used the 1973 and up cross member and the same year big block mounts?
I have a 74 3/4 ton and was going to use all the parts for my 65 C30. Or is it best to update the stock C30 and use the 68-70 mounts |
07-01-2017, 01:08 AM | #55 |
60-66 Nut
You can use the '73+ C20 engine mount brackets as they fit the early frames better than the engine mount brackets from a C10. IMO the clamshell mounts are one of the better engine mount designs.
04-06-2018, 01:48 PM | #56 |
any suggestion on a DIY exhaust system? thanks in advance |
04-06-2018, 02:51 PM | #57 |
Moderator
Those pictures are too small, can you make them bigger so we can see them.
04-06-2018, 03:50 PM | #58 |
04-06-2018, 11:12 PM | #59 |
Here's my 64, 454, 4L80E and 9" ford Rear
01-24-2019, 04:11 PM | #60 |
Really nice looking trucks in this thread and a lot of good bb advice.
Subscribed |
01-25-2019, 04:34 AM | #61 |
Someday, i'll pull the motor, restify the engine compartment and rebuild or replace the 454. For now, it runs well with an Edelbrock EFI installed 20 years ago that came with the truck when I bought it 7 years ago.
09-05-2019, 10:11 PM | #62 |
Just got it sitting in there tonight. What a difference. Looks like these trucks should have came this way. A lot of small stuff to go but looks like headers are a good tight fit and the valve covers clear with no notching at all on firewall. Fan on long water pump is as close as you can get but the good news is no spacer necessary.
Going from this to this. |
09-06-2019, 10:43 AM | #63 |
Moderator
Looks great. Wish I was ballsy enough to put a big block in mine. I had a 502 in 56 big window back in the day. Total heat pump, but I did work out the details and cruised it quite a lot.
