Old 12-29-2018, 01:23 PM   #1
calvin78612
calvin78612's Avatar
Moog 6454
84 stepside 1/2 ton. Complete suspension rebuild/replace. All Moog components. Cpp drop spindles 6454 springs 1 coil cut. Bilsteins on all four corners, flip kit in the rear. How much will the springs settle ? Is it ok to cut half a coil more ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 12-29-2018, 04:39 PM   #2
LEEVON
LEEVON's Avatar
Re: Moog 6454
If they're seated correctly and the suspension has been cycled by driving at least a short distance, they shouldn't settle any more. Are you sure the winding is indexed in the lower arm correctly and seated around, not on the top hat? If yes, sure why not cut more. As long as there is enough spring rate to keep a decent ride and not bottom out go for it.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 12-31-2018, 08:03 PM   #3
SCOTI
SCOTI's Avatar
Re: Moog 6454
Calvin,
It does look a little tall. Trimming more off those springs wouldn't hurt given your drivetrain combo (sbc/auto correct?) vs their rate.
1st..... What is the measurement (@ the hub centerline) from the ground to the fender well lip w/full weight on the suspension?
If you would like to test some stock 1-ton/BBC coils already trimmed I have my old ones you could try.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-01-2019, 10:42 AM   #4
calvin78612
Re: Moog 6454
Originally Posted by SCOTI View Post
Calvin,
R/H 30 1/2", L/H 30". So more trimming on the r/h side. The ride is smooth. Noticed a "pop" noise twice, hopefully just a spring settling into the pocket. I might just try those 1 ton springs. Out to the shop to trim and test drive again. I'll post back shortly.
84 step side
87 swb
Old 01-01-2019, 12:29 PM   #5
calvin78612
Re: Moog 6454
Got it even but still looks high in the front. Drives great just needs alignment. Scoti, I will give those springs a try.
84 step side
87 swb
Old 01-01-2019, 03:13 PM   #6
SCOTI
SCOTI's Avatar
Re: Moog 6454
My dually was @ 27" ride height w/full weight on the suspension (3" spindles, 1-coil cut from the stock springs, & 1.5" notched x-member). Of course there's a little more weight given its a dually w/a all iron BBC.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-02-2019, 12:52 PM   #7
82C10step
Re: Moog 6454
Is there a reason why you used the 6454 instead of the 6452?
82C10step is offline   Reply With Quote
Old 01-02-2019, 01:40 PM   #8
SCOTI
SCOTI's Avatar
Re: Moog 6454
The 6454's increased the spring rate vs. a stock spec V8 spring (since his plan was to cut them shorter).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
