08-11-2018, 03:04 PM | #1 |
BlahBlahBlah
GMC to Chevy headlight question
So when going from GMC to Chevy I know the headlight connections are going to be different. Will I need to change the entire underhood harness, or is there a headlight section only section that I can just swap out?
08-11-2018, 03:26 PM | #2 |
Scrapper 1
Re: GMC to Chevy headlight question
You will need to change the Core support.The GMC is made for 2 head lights not one
08-11-2018, 04:14 PM | #3 |
20' Daredevil (Ret)
As far as the wiring, just use the GMC's outer hi/lo connector for the Chevy's 7" hi/lo headlamps. The inner high-beam-only connector will not be used. If there's not a good way to remove those unused wires completely, I'd at least cap them off to prevent accidental grounding.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-11-2018, 04:20 PM | #4 |
BlahBlahBlah
I already have all I need sheet metal wise. Was just curious about the harness. Ok looks easy peasy as far as the harness goes.
I haven't totally decided on the core support yet. I have the correct one, but I also know the GMC support is easily modified for Chevrolet. Ill have to look and see what all I have bolted to the core support. Its an air truck and it has auxiliary battery. |
08-11-2018, 04:28 PM | #5 |
Bare in mind that if you do as Stocker says, when you hit the dimmer switch you'll be in the dark.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
08-11-2018, 04:28 PM | #6 |
BlahBlahBlah
lol, oops
08-11-2018, 06:28 PM | #7 |
20' Daredevil (Ret)
Explain please? Maybe I'm missing something, but the GMC's outer lamps operate as both high beam and low beam, selectable by the dimmer switch. Chevy's lamps are the same, having both high beam and low beam. They each use the same 3-prong connector (one common wire, one high beam wire, and one low beam wire). So why would you be in the dark?
08-11-2018, 06:38 PM | #8 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-11-2018, 07:01 PM | #9 |
BlahBlahBlah
Ok so basically I should never ever question advice again that I get from Mike?
LOL!!! |
08-11-2018, 08:00 PM | #10 |
EXACTLY! !!!!!!!!!!!!
08-11-2018, 09:40 PM | #11 |
20' Daredevil (Ret)
Now if you guys could convince my wife about that.....
08-11-2018, 10:23 PM | #12 |
I could try but she probably knows you a lot better than I do
08-11-2018, 11:37 PM | #13 |
20' Daredevil (Ret)
After 47 years, I bet she does at that!
