Old 12-26-2017, 09:47 PM   #226
Flames97
Flames97's Avatar
Re: Putting Camaro front in 55 second gen
Really like the how that park break set up worked out! I'm looking at doing the same.
Dies look great too.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 12-26-2017, 09:55 PM   #227
Dave0
I stole the park brake idea from Orrieg . I only shortened it for my taste.
Link to his build http://67-72chevytrucks.com/vboard/s...d.php?t=233305
Dave0 is offline   Reply With Quote
Old 12-28-2017, 01:37 PM   #228
Flames97
Flames97's Avatar
Thanks, I knew I had seen it before somewhere. Great Mod for sure.
-Aaron
Old 01-10-2018, 06:38 PM   #229
Dave0
@Flames97
I fitted and welded my cab corners, I will have to say, they are not easy. I ended up cutting a few inches of the bottom of the inner cab corners off, to keep the water trap problem out. The best way to get the ouuters to fit was to butt weld them. I did put a 3/4 inch "backer" behind it. Now Im where you are at with the poor fitment of the rocker edge. I may get it close and call it good. It is kind of a rat rod...
Got the last seat belt mount tab welded in too!
Old 01-12-2018, 08:23 PM   #230
Dave0
Dash extension about done. The lt emboss is for the parking brake release. There will be a A/C vent next to it. The center piece will have 3 A/C vents and two embossed areas for the fresh air vent pull cables. I trimmed everything close the allowed for a rubber gasket on each end and around the column. Time to take this thing all apart and do some grinding and get the bottom and firewall all painted up! I'll post some more pics up when I get the cab back on the frame.
Old 01-12-2018, 08:45 PM   #231
Indian113
Indian113's Avatar
Looking Good! I like the Dash Extension, Nice pictures of Cab Corners they help someone that will have to do their own.
Indian113 is offline   Reply With Quote
Old 01-12-2018, 09:06 PM   #232
Dave0
Thank you, believe it or not, I beat that dash extension over a piece of pipe with a block of wood to get the radius at the bottom. I got tired of waiting on the sheet metal shop to fab me one up...
Old 01-13-2018, 01:25 AM   #233
Rods57
Rods57's Avatar
cool dash,
Rods57 is offline   Reply With Quote
Old 01-13-2018, 10:17 AM   #234
bowt1ed
Dave, love the look of your dash extension. Would appreciate any info or pics of how you fab'd yours. Great work!
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 01-13-2018, 12:28 PM   #235
Dave0
Cheers, Jim
Thank you guys, here is a drawing of what I did. The glove compartment will be completely bolted on and non-functional. I will end up making some brackets to stiffen it up some and welded to the back. (2nd pic) I used a bunch of the factory holes in the original dash to bolt the lower on. I had to drill one one the far right side and that was it.
Let me know if this makes since.
3rd and 4th pic, trying to decide on square or round vents? Im kind of partial to the square...
Old 01-13-2018, 03:29 PM   #236
bowt1ed
Thanks for the info. With the roundness of everything else, I would initially sat the rounds would look better, but they're too big. I think an oval or rounded corner rectangle would look best. Just my thoughts.
Cheers, Jim
Old 01-17-2018, 02:26 PM   #237
Flames97
Flames97's Avatar
Wow!! That lower Dash portion came out great. I've been wanting to do that as well.
Cab corner looks like it came out really good.
-Aaron
Old 01-17-2018, 07:49 PM   #238
Dave0
You may be in luck! I got a extra un cut piece to do another dash....
Old 01-26-2018, 09:53 PM   #239
Dave0
Some shtf boxes added to the step area, also will hold some 6.5 midbass drivers. Getting everything blasted and sanded for paint.
Im going to weld bond a outter skin on these after I get everything epoxied and seam sealed.
Old 02-02-2018, 10:54 PM   #240
Dave0
Going back on the frame tomorrow! Good feeling!
Old 02-03-2018, 09:32 AM   #241
Kim57
Kim57's Avatar
Looks good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-03-2018, 07:50 PM   #242
Dave0
Originally Posted by Kim57 View Post
Looks good.
Kim
Thanks Kim! You been putting any time in yours?
That moment you realize that 2 years of making part and modifying every damn part starts to pay off!
Old 02-04-2018, 12:54 PM   #243
56hotrodred
Hey that lower dash extension looks great.
I have been thinking about that for quit a while also! I really don’t want to cut up my virgin dash for air conditioning vents.
I would be willing to pay you for a blank one if you could produce another one.
Good job.
56hotrodred is offline   Reply With Quote
Old 02-15-2018, 03:53 PM   #244
Flames97
Flames97's Avatar
Nice Progress!!! Looks awesome!
-Aaron
Old 02-17-2018, 10:26 PM   #245
Dave0
Good job.
I have a few I made...
Old 02-18-2018, 02:08 AM   #246
56hotrodred
Well if you are willing to part with one; how much would you need and how can we ship to me in Arizona and what is the best method of payment?
I am in Arizona for another 3 or 4 weeks and then back up to Alberta. Once back home we could ship to Montana and I can run down and pick it up.
Whatever is best for you!
Old 03-08-2018, 08:44 AM   #247
Dave0
Shoot me a pm...
If you be real nice to Vintage air, they will sell you one of these plenums with 4 hose ends and vents that will go right into the dash with hose ends on them !
Old 03-08-2018, 09:41 AM   #248
Az. Hank
Az. Hank's Avatar
How did you make the recessed holes for the vent rods?
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 03-08-2018, 01:07 PM   #249
Dave0
Check out post 223. I made some dies and pressed them in using a shop press.
Old 03-10-2018, 01:49 AM   #250
Az. Hank
Az. Hank's Avatar
Thanks, I just went back and cought up.
My 55 Build 55 C-4
