Old 05-14-2018, 10:14 AM   #1
70GMCer
70GMCer's Avatar
What is this wire
Found this under the carpet.
Anyone know what this wire is for?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-15-2018, 03:32 AM   #2
chengny
chengny's Avatar
Re: What is this wire
IDK how the circuit is currently wired/routed - but some modifications must have been done. As original:
The cut leads went to the switch for the backup lights.
DK BLU is/was hot from the fuse block (fed by the 15A TURN B/U fuse)
LT GRN supplied the B/U lamps - via the rear lighting harness.
Because of the presence of the grommet, it's likely that the transmission was changed from a 4 speed manual to either a 3 speed manual or an A/T. The B/U light switch used with a 4 speed MT is mounted on the transmission, while the other two types are located in the cab.
chengny is offline   Reply With Quote
Old 05-15-2018, 06:51 AM   #3
70GMCer
70GMCer's Avatar
That would explain why I have no backup lights then.
The truck is an original auto trans. So, is the backup light switch located on the column?
Is it a part of the neutral safety switch?
Thanks for the help on this...
1997 GMC Sierra Ext
1965 Mustang
