07-15-2018, 09:45 PM | #1 |
Needing 235 I6 air cleaner
Looking for an air cleaner for my 61, not sure if there’s a piece missing on the top of the carb that would have a stud and wing nut or what. Here’s what I’m dealing with..
07-15-2018, 11:59 PM | #2 |
60-66 Nut
Re: Needing 235 I6 air cleaner
I believe there is supposed to be a piece across the middle, screwed to those 2 holes on each side with the stud in the middle.
07-16-2018, 01:05 AM | #3 |
I have the air cleaner, but I don't have the hardware missing from the carb
07-16-2018, 02:52 AM | #4 |
Is it an offset? Or do you have pictures of the air cleaner you’ve got at least? Thanks
07-16-2018, 03:37 AM | #5 |
I have a air cleaner off a 1960 that will work. I will see if I can find the part that goes on the carb that holds the air cleaner to the carb.
07-16-2018, 08:52 PM | #6 |
It's a stock oil bath off a '61 235. Here's a pic.
07-17-2018, 11:28 PM | #7 |
I bought a carb today that has the stud out of the top so hopefully I can use it. What are you looking to get for that air cleaner?
07-19-2018, 11:09 PM | #8 |
Still looking for an oil bath cleaner
