Old 04-04-2014, 11:24 AM   #1
fun in dirt
fun in dirt's Avatar
? motor running noise in dash
Got a '01 Suburban 2500 6.0...when the key is on, I can hear some type of small motor running. It's not real loud but noticeable. Sounds kind of like heater/ac blower motor, but does it even when that is all turned off. Seems to be coming from somewhere around center of dash.
Just curious as to what this sound is?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 04-04-2014, 09:06 PM   #2
Boog
laying low
Boog's Avatar
Re: ? motor running noise in dash
Some of the 2000 and up trucks have a small deal just above your head in the headliner that just may be the source of your noise. My 06 crewcab and 03 Tahoe both have these and both make a sort of buzzing noise. Real noticeable when the radio is turned down. It stops when the key is turned off. I think I was told it is a small blower/sensor deal for the climate control or something.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-04-2014, 09:23 PM   #3
Special-Ed
Special-Ed's Avatar
It's normal. There are something like 8 motors in the dash. They cycle when key is turned on. Regardless if heat is on or off
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 04-07-2014, 11:15 AM   #4
fun in dirt
Hmmm interesting - thanks guys!
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 04-07-2014, 03:02 PM   #5
68Stepbed
68Stepbed's Avatar
What about a thumping sound? At times, the dash in my 05 sounds like it has critters thumping around in it.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-07-2014, 06:40 PM   #6
Special-Ed
Special-Ed's Avatar
could be the blend doors... again normal
Old 04-07-2014, 07:21 PM   #7
Boog
laying low
Boog's Avatar
Matt, turn that radio down.
Boog
primer is finer
Old 04-07-2014, 07:27 PM   #8
68Stepbed
68Stepbed's Avatar
I have to turn up the radio to block it out.
Matt
