Old 05-31-2019, 04:11 PM   #1
domano 68
How to flip seat back forward
Just picked up a new to me, 71 Cheyenne Super. Wondering how the seat back (bench seat) blips forward so i can access behind the seat area? Thanks in advance!
1971 C10 127 in wheelbase
Model Number-CS10934
Body Type & Seating-Fleetside 8 ft.
Original Factory Price-$2,854
Shipping Weight-3,605 lbs
Total Production-206,313
domano 68 is offline   Reply With Quote
Old 05-31-2019, 04:44 PM   #2
jbarron
Re: How to flip seat back forward
They don't flip forward.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 05-31-2019, 05:33 PM   #3
RustyPile
RustyPile's Avatar
jbarron is correct.. The seat doesn't "flip" forward.. However, if you need to access the fuel gauge sending unit, you can remove the 4 (2 on each side) seat mounting bolts in the rear and loosen the front 4 bolts.. Tip the seat forward and place a block of wood under each rear "foot".. This will allow you to gain access to the sending unit without fully removing the seat... Replace and tighten the bolts when you are finished.. Don't drive the truck with loose or removed bolts..
RustyPile is offline   Reply With Quote
Old 05-31-2019, 05:49 PM   #4
Willys_MB
Willys_MB's Avatar
I'm no expert, but my bench seat leans forward. I think there's some extensive discussion about this on the forum. I vaguely remember something about it changing based on year?
Either way, pulling the seat isn't very hard if you need to access that area.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 05-31-2019, 10:27 PM   #5
leddzepp
Moderator
leddzepp's Avatar
67-68 fold forward, 69-72 do not
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 05-31-2019, 10:58 PM   #6
FirstOwner69
FirstOwner69's Avatar
The change was made in '69 as required by new safety regulations. Same with 2 door cars which were the first to have latches on the front seat backs.
FirstOwner69 is offline   Reply With Quote
Old 06-01-2019, 11:16 PM   #7
domano 68
Good to know, thanks!
Interesting. Seems like a step backwards though. I wonder if they thought about how do people access the area behind the seat.
Old 06-02-2019, 12:17 AM   #8
Madkidd007
Madkidd007's Avatar
Unsure if it’s correct for my truck as it’s how I got it 15 years ago. But my 70 appears to have angle adjusters that just had the lower lock nuts removed and now it flipped forward
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 06-02-2019, 07:34 AM   #9
Grumpy old man
Grumpy old man's Avatar
That's a 67- early 68 flip seat Later 68 -72 bolted solid with the upholstery covering the arms .
Old 06-02-2019, 11:08 AM   #10
72c20customcamper
72c20customcamper's Avatar
Actually GM and most other companies made the change over in 67. My 66 chevelle has flip seats no latch buttons which is correct . I have 67 gto seats that have the button releases. It also has the mounts for the three point seat belts. Even though they weren't installed.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-02-2019, 01:00 PM   #11
cardude
cardude's Avatar
Question Re: How to flip seat back forward
While we're on the subject then, what would make good fold-forward bench seat candidates for swapping into our rigs?
I know that I wish there were a couple more inches between me and the steering wheel; I'm always trying to push myself back.
So a really thick, plush seat would make that worse for me. (and I don't have much of a beer belly either!)
cardude is offline   Reply With Quote
Old 06-02-2019, 01:53 PM   #12
leddzepp
Moderator
leddzepp's Avatar
If you need more room between you and the steering wheel, collapse your intermediate shaft and bring the column closer to the dash. Changing a seat will not gain you any room. Once the seatback hits the cab, it isn’t moving back any further unless you angle it forward, making it uncomfortable and unable to lean back.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 06-02-2019, 02:12 PM   #13
FirstOwner69
Thanks for the clarification. When I posted, I thought that it may have been a year or 2 earlier on the cars. We had a '69 Olds 2 door which was the first time I'd seen them.
Old 06-02-2019, 03:48 PM   #14
cardude
cardude's Avatar
Thanks Leddzepp! Didn't really think of that!
I've got my brake booster out right now anyway for some major re-wiring at the firewall........................"as long as I'm here"!!
Anyone got pics of moving the neutral safety switch back? It looks pretty close to the firewall already!
Old 06-02-2019, 07:00 PM   #15
68Gold/white
Those seat lowering brackets, that someone sells...might help...
68Gold/white is offline   Reply With Quote
Old 10-22-2019, 01:35 PM   #16
demian5
demian5's Avatar
Can a non folding seat be made into a folding seat?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
