12-26-2017, 10:58 PM | #1 |
Need a drop spindle recomedation
Ok guys I have western 2.5 71-72 drop spindles currently. I have pb fab forward and narrowed arms with bags. Problem is That I run 15" wheels and would like to install heims on the bottom side of tie rod mount to clear up bumpsteer. I dont think it will clear the tire and rim. Are there any drop spindles on the market that move the tierod mount inboard some? I have heard beltech does. I would not have a problem with a 2" drop insted of 2.5 for wheel clearance.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
12-27-2017, 03:58 PM | #2 |
Re: Need a drop spindle recomedation
Looking @ the pic.... The TRE looks to be pretty close level wise as the lower a-arms (pivot point to BJ). Moving the TRE to the bottom of the spindle steering arm would have them much different vs where they are now & would not help a bump-steer issue. It would make it worse.
You want them as close as possible level/angle wise.
12-27-2017, 04:44 PM | #3 |
I think the angle of the pic may be misleading
12-27-2017, 05:00 PM | #4 |
Yep, the pic was mis-leading.
12-27-2017, 05:03 PM | #5 |
Lol, i was zooming in on the potential clearance issue and where i was hoping to find a spindle that is pulled in a bit🤣
12-27-2017, 05:15 PM | #6 |
Would there be enough room if the TRE was flipped or would that be an interference issue as well?
12-27-2017, 05:37 PM | #7 |
I ordered more custom sleeves, heims and misalignment bushings today. Gonna try it out. Total width is 1.83. We shall see
01-03-2018, 03:35 PM | #8 |
A guy with a truck
Where did you get your taper sleeves?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-03-2018, 03:37 PM | #9 |
Got it all from rod end supply!
