Old 02-25-2018, 06:14 AM   #26
Aus69c20
Aus69c20's Avatar
Re: Install thread- Holley EFI Sniper on '72 402 big block
Thanks for posting this info.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 02-26-2018, 11:41 PM   #27
Old_Gold
Old_Gold's Avatar
Great write up and videos! this is definitely making me rethink my plan for my truck. I was planning to drop a TBI 350 with a 700r4 in my 72, but now think the extra headaches may not be worth it.
How do you guys think the sniper or FiTech systems compare to the late 80s tbi for power, drivability, etc?
Thanks,
Jim
Old_Gold is offline   Reply With Quote
Old 02-27-2018, 12:32 AM   #28
Steeveedee
Who Changed This?
Steeveedee's Avatar
I went and looked at prices. Am I mistaken that these systems are $3500, plus or minus? Not picking on anyone, just trying to be sure about costs.
~Steven
Simi Valley, CA
Old 02-27-2018, 12:45 AM   #29
TXgearhead67
They run about $1000.
TXgearhead67 is offline   Reply With Quote
Old 02-27-2018, 04:37 AM   #30
Aus69c20
Aus69c20's Avatar
Old gold.
I think the big advantage these new units have over the older tbi units is much more computing power. Which allows an ability to self learn and more accurately compensate for different conditions.
That is my understanding
John
Old 02-27-2018, 08:48 AM   #31
Ekliptix
Ekliptix's Avatar
Thanks,
Jim
I was looking at FI tech for a while. I read their support went downhill with the large volume of sales then ended up getting. With Holley, it's a big company and I feel I can get better support.
$1000 plus $300 for the optional fuel system.
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt.
Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD.
Ekliptix is offline   Reply With Quote
Old 02-27-2018, 11:15 AM   #32
Lieferson
Lieferson's Avatar
I just finished the Install of the sniper EFI on my 72 K10 yesterday, You're going to love it!
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 02-27-2018, 11:51 AM   #33
Ekliptix
Ekliptix's Avatar
I'm about to call Holley for a support question. Maybe you can chime in. The Yellow wire from the Holley harness is supposed to measure RPM. Do I hook it up to the same wire that goes from my distributor to my tach (brown wire)? The instructions are not 100% clear to me.
Old 02-27-2018, 03:57 PM   #34
Lieferson
Lieferson's Avatar
I have an MSD box, so the yellow wire was not used, so i wont be of any help sorry!
Old 02-27-2018, 06:04 PM   #35
Ekliptix
Ekliptix's Avatar
Holley told me I have to use the brown wire on the optional 10 pin connector to now go to my tach. The yellow wire on the 7 pin connector will go to where my original tach signal came from on the distributor.
Old 02-27-2018, 09:55 PM   #36
Old_Gold
Old_Gold's Avatar
Aus79c20 and Ekliptix, thanks guys, I think I'm headed down this path!
Jim
Old 02-28-2018, 01:42 AM   #37
Ekliptix
Ekliptix's Avatar
Made some wiring progress tonight.
This is an optional 10 pin connector. Most of the wires are for nitrous, etc, so I cut and heat shrinked most of them. I only need the brown wire remaining to send a signal to my tach.
Started getting some things tucked away. I need to buy some black wire loom to cover those 3 wires at the top. I attached the fuse and relay to a screw by that AC box thing.
Tried to hide the wires as much as possible. This is the power from the battery, ran through the fender.
What's left is connecting a blue wire (power) to the fuel pump, grounding the fuel pump, ensuring the O2 sensor cable is secure, terminating the yellow wire to the distributor tach signal, connecting the brown wire to the tach, connecting the pink wire to 12v when the ignition is on.
Then put some gas in the tank, follow the start up instructions including priming the pump and dumping gas into a can to fill the source hose with fuel.
The end is in sight!
Old 02-28-2018, 10:49 AM   #38
TXgearhead67
Lookin good. I’m anxious to see how it does with that big cam and low vacuum.
Old 02-28-2018, 11:30 AM   #39
Ekliptix
Ekliptix's Avatar
Yea, I have not 100% identified what the low vacuum is from. This EFI unit won't fix a vacuum leak but i'm not sure if that's what I have.
Old 03-05-2018, 11:57 AM   #40
Ekliptix
Ekliptix's Avatar
Good news and bad news.
The good: The truck is running!!! It idles super smooth and there's no unspent fuel coming out the exhaust.
The bad: There's coolant leaking from the intake manifold where a crack has appeared, likely from me over tightened the heat temp sensor.
Need to do:
1) replace/fix intake manifold where it cracked.
2) adjust throttle cable to provide 100% open throttle. Reads 85% position at peddle WOT.
3) wait 3 months for snow to melt
Part 3 Video: https://youtu.be/JSnHy1DTm8E
Finished engine bay
Running and warming up
Me "What's that sound?"
Green juice is good, right?
Random pic of chains used to get 1 car and 2 trucks unstuck from my driveway this weekend. 305 studded winter tires, love 'em.
Old 03-05-2018, 12:37 PM   #41
Rufas
Rufas's Avatar
Actually the FiTech systems start at $795. I've got two Fitech systems installed. One on my supercharged 70 GMC and another on my 67 Cutlass with a 468 BBC. I installed the FiTech on the Cutlass over two years ago. I'm using the FCC on the Cutlass without issues. The problem with the FCC is most people mount it on the firewall or near the exhaust. My is mounted directly behind the left headlight. Never had a problem with it. Both units are performing flawlessly. I'm very happy with FiTech EFI.
As far as tech support the few times I've called they have answered quickly and answered my questions. I don't call on Mondays since that is their heaviest call volume. There is a Facebook FiTech Owners group that has great info and help. It appears most problems are user who can't follow instruction and cause their own problems.
$795 -FiTech Go Street EFI 400HP Self-Tuning Fuel Injection Systems 30003
70 GMC Supercharge 350
67 Cutlass 468 BBC
1970 GMC 2500
700R Trans
RideTech 4 link rear suspension - Air Bagged on all four corners
350 SBC 300hp
Weiand Supercharger
FiTech EFI
Rufas is offline   Reply With Quote
Old 03-05-2018, 01:21 PM   #42
TXgearhead67
Good video bud. The truck sounds good. I may have missed it but what size cam are you running and how much vacuum are you pulling? The sniper is the route I’m going I just need to find a cam that’ll pull enough vacuum. Thanks.
Old 03-05-2018, 01:46 PM   #43
Ekliptix
Ekliptix's Avatar
I'm trying to find my cam specs, but this is what the holley instructions say:
Stock/Mild = This selection will work well on most applications equipped with stock or “street performance” camshafts. Choose Stock/Mild If you are unsure of your camshaft specs.
Street/Strip = Select this if your engine has between 8” and 13” of manifold vacuum.
Race = Select this if your engine has less than 7” of manifold vacuum. Race oriented camshafts may require laptop tuning for optimal idle stability.
Old 03-05-2018, 02:02 PM   #44
TXgearhead67
I’ve been looking for that info and couldn’t find it. That’s doable. Thanks bud.
Old 03-16-2018, 08:12 PM   #45
54Caddy
GM Addicted
54Caddy's Avatar
Looking good so far. I’m also installing a few sniper EFIs on a few customers vehicles. On that 10 pin connector I went further and removed the actual pins from the harness and installed the correct cavity plugs in connectors. I can post the part numbers and tool needed to do that if you’d like. On the 67 I will be doing I’m going to have the stock tank cleaned and have bungs put on bottom of it. Your not afraid of fuel issues with the pump having to pull from stock line as well as starvation issues?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-17-2018, 12:20 PM   #46
davepl
davepl's Avatar
I'm impressed how quickly it fires off - I have an older BigStuff3 system which uses dual sync (cam and crank) for sequential injection but that in turn means the engine has to go through one and perhaps two full revolutions before it can fire off while cranking.
This one seemed to light off right away, which is much nicer!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-18-2018, 09:49 PM   #47
Ekliptix
Ekliptix's Avatar
I'll pass on the pin remover for now, thanks.
Regarding fuel starvation with the stock line/pick up, the EFI unit won't consume any more then a 750 carb so I can't imagine an issues. The engine previously dynoed at 430hp. Thoughts?
Old 03-19-2018, 04:45 PM   #48
Fraud
the 750 carb also has float bowls that store enough fuel to cover you in the event that fuel sloshes away from the tank pickup while cornering etc., which is a luxury you don't have in a high pressure EFI system... Probably fine if you never have less than 1/3 of a tank though...
Historically solved with surge tanks and so forth, but you'd be doing me a big favor if you tried out a holley hyrdamat in a stock tank and posted results
Fraud is offline   Reply With Quote
Old 03-19-2018, 06:54 PM   #49
clay68c10
clay68c10's Avatar
In my previous 68, I ran a 454 with a hopped up GM TBI using the stock pickup tube and in-cab tank and it never sucked air. I ran the tank pretty low a few times just to see. It helps that it is such a tall and narrow tank.
My Caddy tank has similar dimensions but is flat under the trunk floor. I had to add a sump or it would suck air at anything less than 1/2 after I put efi on it.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-20-2018, 09:37 AM   #50
Benjamin
Benjamin's Avatar
subscribed
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels
1976 K20 crew cab, 350/Ranger/SM465/NP205
Benjamin is offline   Reply With Quote
