Old 09-14-2020, 10:59 PM   #26
clinebarger
Re: Which Coolant to use in a new L31, and which intake gasket?
Originally Posted by derotoreut View Post
Heard nothing but bad about Dex Cool. Don't have any experience with it though. Never heard any bad about the old green. I used standard Prestone in my 5.3L swap.
Dexcool is an outstanding coolant when used properly & actually lasts longer than 5 years/150,000 miles.....It's more of a 10 year/300,000 mile coolant in the right applications.
The main corrosion/rust inhibitor is 2-EHA (which stands for 2-ethylhexanoic acid) & has 3 drawbacks......
*If ran low & cast iron gets exposed....It will quickly rust & the rust will migrate to the heat exchangers (Radiator & Heater Core), Not an issue with all aluminum mills & unlikely to happen on Aluminum Headed mills. Maintaining proper level is very important!!!
*2-EHA is known to be a Plasticizer (Softens Plastic) & did no favors to the Plastic Frame gaskets used on Vortec 350's.
*The Organic Acids don't play well with Soldered Copper/Brass heat exchangers, Not that I believe the Acid eats away at the Solder, But removes the Silicates that was plugging the tiny pinholes that were already there.
Air exposure in a remote coolant recovery reservoir in itself does nothing to Dexcool!
Mixing incompatible coolants & off course....Running the level low enough to expose cast iron is when you see the "Death Cool" build-up.
clinebarger is offline   Reply With Quote
