Old 02-07-2018, 01:06 PM   #1
jlindquist
35" tires with 3.73 gears
I currently have 3.73 gears pushing 35" tires down the road. I am considering upgrading to 4.56 gears but am afraid I will lose my 65+MPH highway driving ability. I was curious what options, if any, I may have to possibly add a fifth gear to my stock 4 speed manual transmission.
Any thoughts?
jlindquist is offline   Reply With Quote
Old 02-07-2018, 01:15 PM   #2
SeventyOne
Re: 35" tires with 3.73 gears
split the difference and do 4.11s?
Do you not like the sluggishness off the line with 3.73?
Seems to me a trans swap to get that 5th gear would be the most work of your options.
SeventyOne is offline   Reply With Quote
Old 02-07-2018, 02:01 PM   #3
Lieferson
Lieferson's Avatar
Im running 3.73 with the sm465 and 35s, it goes pretty good for me. I agree with the above statement though. move up to 4.10s and you should be good to go
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 02-07-2018, 07:41 PM   #4
jlindquist
4.11's may be the easiest, most cost effective way. Doesn't seem like much of a jump from what i have. Do you think i will see a noticeable change?
Old 02-07-2018, 08:09 PM   #5
rsavage
rsavage's Avatar
Randy's calculator shows 2565 rpms at 65mph with 35" tires with 4.11 rear gear
https://www.ringpinion.com/calculators/Calc_RPM.aspx
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-07-2018, 09:01 PM   #6
Mike C
Mike C's Avatar
Transmission? 3.73 and 35's should be a decent combo. I run 35's with 4.10 and SM465 in my Jimmy. The Jimmy we are screwing together for my teenager is getting 3.73 with a TH350. With converter slippage, they are both probably equal in terms of highway RPM.
Maybe a cam swap to get a little more cruising RPM torque will make the difference and a lot cheaper than swapping gears in both ends. Dual exhaust, HEI and good tune.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-07-2018, 10:01 PM   #7
jlindquist
This is a great tool thank you
Old 02-07-2018, 10:04 PM   #8
jlindquist
It’s a stock 4 speed. I have a newer crate motor with a mild cam in it now. The diffs are stock and due for an overhaul (bearing and seals), so I might as well replace the ring and pinion while I’m in there
Old 02-07-2018, 10:18 PM   #9
Mike C
Mike C's Avatar
I did ring and pinion swaps in my truck in the late 80's. I think I broke the 12 bolt in some way 8 or 9 times? My truck has a semi-float 14 bolt from an '86 3/4 ton Suburban and we just pulled a set of 3.73 geared axles from an '84 Sub for my kids project. Both of the 9.5" axles have Gov-Locks in them and we are putting a TransAm clutch posi in the front of his.
I can't see spending $1000 to re-gear your axles and less it is REALLY important to you. But you can probably find a beater Suburban and pull the 8 lug axles from it. (I paid $300 for the 4.10 equipped truck that was equipped with HD towing an TH400. The 3.73 truck had a TH700R4 and was $200.)
As you can see, if it were mine I would also be looking for a strength upgrade at same time.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-09-2018, 11:42 AM   #10
PSYCHO_OUTLAW
My blazer has pretty much the same setup but I am running 33s. However, I feel like on the highway the RPMs are way to high. At 65 MPH i am at 3500 RPMS continuos. Which I feel is way to high. I have thought about getting a NV4500 for the 5th gear set up. I am also swapping to 3/4 ton axles and I believe the rear is 4:10 or 4:11. I feel like that setup would be more suitable for hwy/street
PSYCHO_OUTLAW is offline   Reply With Quote
Old 02-09-2018, 12:26 PM   #11
hemi43
hemi43's Avatar
3500 RPM @ 65MPH ? How is this possible ?
hemi43 is offline   Reply With Quote
Old 02-09-2018, 12:35 PM   #12
PSYCHO_OUTLAW
I am not sure.. but it def dont seem like it will be good for the truck in the long run.
Old 02-09-2018, 01:41 PM   #13
SeventyOne
Yeah Psycho you gotta check that out - The math on randy's ring and pinion calculator doesnt add up.
I had to put in 4.56 gears, 33" tires and 75 mph to get to 3500rpm...
Your speedo could be off but your gear ratio cant be that far off. Are you sure you're getting into 3rd gear in the trans (1:1)? EDIT oh its a manual..guess you'd know if you got in gear lol
Old 02-09-2018, 05:44 PM   #14
PSYCHO_OUTLAW
The speedo is off.. but i use a speedo app to gauge it... and maybe the tach is wrong... since its factory and old... but I dont believe it is too far off if it is... it does not purr down the hwy like i think it should... eitherway.. hopefully soon I will be installing the 14 bolt.
Old 02-09-2018, 08:23 PM   #15
jlindquist
i was hoping i could get by with one of these, but with the short wheel base, the driveshaft angle would be too extreme. These add 13" to the rear of the transfer case. The NV4500 may be the best option long term.
http://www.gearvendors.com/4x4.html
Old 02-09-2018, 09:20 PM   #16
Mike C
Mike C's Avatar
My truck runs 2500 rpm at 70 with the 4.10. With 33's, you are about 10% more but 2750 is a LOT less than 3500. One of your numbers is off somewhere.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-09-2018, 09:31 PM   #17
mongocanfly
mongocanfly's Avatar
physco what trans are you running? I use the csg rpm calc..but using it and assuming your final trans gear is 1:1 at 65mph with 33in tires and 3.73s you should be at 2469rpm....
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
