Old 09-18-2018, 10:56 PM   #1
capriceutah
Crossmember swap woes.72 clip into 64 c10
Guys and Girls,
I pulled my crossmember out of my 64 c10 to swap to a rebuilt setup for a 72.
When I pulled all of the bolts on the 64 c10 crossmember, it didn't just drop out of the truck. I had to pry it a little.. not hard but a little. Now I'm trying to swap the 72 in and I cant get it to slide in. It's like the frame where the crossmember bolts in is like 1/4 inch too wide.
Has anyone run into this before(I'm sure someone has) and what are my options?
Thank you for all of your help!
Chris
capriceutah is offline   Reply With Quote
Old 09-19-2018, 12:07 AM   #2
Captainfab
60-66 Nut
Re: Crossmember swap woes.72 clip into 64 c10
Just use a bar clamp or maybe a couple of ratchet straps to squeeze the frame together a little.
Old 09-19-2018, 07:14 PM   #3
capriceutah
Perfect! Thanks for the response.. Cant wait to get the brackets installed!
Chris
Old 09-22-2018, 10:58 PM   #4
capriceutah
Captainfab,
Your strap suggestion worked like a champ!
Thanks,
Chris
Old 09-29-2018, 02:55 PM   #5
BabyBlue64
Can someone tell me if it is possible to use a crossmember out of an '82 suburban with diesel engine under my '64 with straight 6? Or do I get problems with my motormounts?
BabyBlue64 is offline   Reply With Quote
Old 09-29-2018, 03:49 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
You really don't need to do that unless your cross member is bent or something. The later control arms will bolt up to the early cross member.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Truck pictures: http://s49.photobucket.com/albums/f2.../The%20Trucks/
Chevy Fleetside is offline   Reply With Quote
Old 09-30-2018, 12:07 AM   #7
Captainfab
60-66 Nut
That is true unless the '64 in question is a C20.
Old 09-30-2018, 12:10 AM   #8
Captainfab
60-66 Nut
While I have not swapped the suspension crossmember under a truck with a I6, the engine mounts should bolt in. If not, worst case you may have to drill the holes in the crossmember for the lower bolt of the engine mount brackets.
Old 09-30-2018, 10:37 AM   #9
Chevy Fleetside
yes.. I am going on the assumption that it is a C 10. I will have to mention that if I ever put my 2 cents in next time.
Old 09-30-2018, 11:05 AM   #10
BabyBlue64
Thank you Guy's for the info. My truck is a C10. I didn't knew the newer A arms just bolt on the older crossmember. I want to use the diskbrakes of the Burb onder mine.
Old 09-30-2018, 11:28 PM   #11
Captainfab
60-66 Nut
And you don't have to change the control arms either. You can simply change the upper and lower ball joints to the later model ball joints for the disc brake spindle.
Old 10-02-2018, 09:21 AM   #12
Chevy Fleetside
http://www.67-72chevytrucks.com/vboa...isc+brake+swap Yep. I did that to mine. Well one of mine and they work just fine.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
