12-17-2016, 10:49 AM | #1 |
scott's weld in ifs need info
The instructions say to mark centerline of old front suspension. and I am starting with a bare frame. Does anybody have a reference point of centerline on their 68 front suspension? Has anybody installed a weld in version? Need info
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
12-26-2016, 11:07 AM | #2 |
Re: scott's weld in ifs need info
still looking for help
12-26-2016, 12:03 PM | #3 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Kinda vague on the question so I'll ask you some. What's a "Scotts weld in?" You say you have a bare frame, how bare? Got some pics? A bare frame can mean no front cross member or axle...?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
12-26-2016, 05:08 PM | #4 |
no front cross member or rear axle just a couple mid crossmembers. I want to weld in a IFS from Scotts hot rods. and without the front suspension, I need to draw a line from front spindle to other front splindle. I need to know where it crosses the frame
12-26-2016, 09:39 PM | #5 |
I know the frame drawings are in the 60 to 66 FAQ section that show all the locations and measurements. Not sure if they are in the 67 to 72 section. You could post in the regular truck section and ask if any one has a frame sitting around that can get you measurements. Lot more chances someone will see the request. A better title would be "Need frame measurements" and post the year and length of the frame you need measurements off of.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
12-27-2016, 11:19 AM | #6 |
Going by others measurements might not be the best approach here (where they're pulling measurements from; how they're measuring, etc...).
Besides the frame rails/mid x-members, how much more of a truck do you have? I would drop the cab on the frame & mock the front fenders up to get a visual of where you want things & work from there.
12-27-2016, 05:30 PM | #7 |
found the dimensions I needed from a 67-72 chevy service manual.
Thanks for the feed back
12-30-2016, 12:16 AM | #8 |
If i would of seen this before i would of helped out i had the same questions when installing mine on my truck if you want look thru my build thread theyre should be piks on theyre of when i installed it im tryin to load some here but its giving me a hard time
12-30-2016, 12:25 PM | #9 |
hey low69chevy...did you have to spread the frame, to weld in the Scotts cross member?
I am about ready to box in the frame and weld in the motor mounts,
12-30-2016, 05:31 PM | #10 |
laying low
I'm sure you have a good reason for replacing the well designed GM front suspension but if i were you i would contact Scotts for their reference points since they designed their setup
12-30-2016, 07:34 PM | #11 | |
Heres some piks i copied and pasted off my thread it shows when i got the old one off and with the Scotts crossmember on Last edited by low69chevy; 12-30-2016 at 07:53 PM. |
12-31-2016, 09:58 AM | #12 |
is that a Scotts weld in ifs, mine have different ball joints. Is you truck back on the road yet?
12-31-2016, 12:38 PM | #13 |
Yes its the scotts weld in and no im still working on it
