Old 05-19-2023, 12:02 PM   #1
pmagrum
pmagrum's Avatar
temp send unit?
Trying with no success to replace temp send unit 1982 C10 silverado 305 H engine with gauges Made in Canada Engine is blue not chevy red old unit is nail head design have had the truck since 20 k so i feel that it is original,
was given a standard part TS6 Gauge read proper with boiling water and thermometer BUT the physical size for entry to block was too big. Any suggestions Please
pmagrum is offline   Reply With Quote
Old 05-19-2023, 11:48 PM   #2
dmjlambert
dmjlambert's Avatar
Re: temp send unit?
It may be possible to have a machinist turn and re-thread the sender to fit the smaller threaded hole, works for the issue in 67-72 trucks. In my case for my 1969 truck the sender to work with stock gauge was part number is G1852 that looks very similar to your TS6. https://67-72chevytrucks.com/vboard/...d.php?t=703388
Old 05-20-2023, 12:18 AM   #3
franken
Re: temp send unit?
NAPA says they have one for that truck but it doesn't look like the one in your pic.
Old 05-21-2023, 09:39 AM   #4
TKCR
TKCR's Avatar
Re: temp send unit?
Had that same issue with mine. I got an adapter from Lowe’s.
Old 05-21-2023, 10:18 AM   #5
pmagrum
pmagrum's Avatar
Re: temp send unit?
thanks for the reply thought about this. It takes it out of the water flow. did it effect the temp readings any when you did this?
Old 05-21-2023, 10:41 AM   #6
TKCR
TKCR's Avatar
Re: temp send unit?
No problems at all. Here’s a close up pic.
Wish I had a picture of the sensor with the adapter before I installed it. The adapter did not change the depth of the sensor itself in the block. All it did was make the correct size of the new sensor to fit into the block.
Old 05-21-2023, 11:35 AM   #7
pmagrum
pmagrum's Avatar
Re: temp send unit?
do you remember if you used a ts6 sensor. that one worked with my gauges (using ground wire , boiling water and a meat thermometer) size was the problem larger thread diam than the original
Old 05-21-2023, 12:18 PM   #8
TKCR
TKCR's Avatar
Re: temp send unit?
Can’t say for sure unless I looked up the info. It was 7-8 years ago when I did this. But it is the correct one for my engine and temp gauge, which is stock. The PO had an aftermarket sensor & gauge. But I went back to using the original. There was nothing wrong with the temp gauge, so I’m not sure why he went with an aftermarket one. It was mounted to the bottom of the dash.
I also found this picture of all the stock temp sensors.
Old 05-21-2023, 03:00 PM   #9
pmagrum
pmagrum's Avatar
Re: temp send unit?
Gona get adapter tomorrow and try that. Thanks for your time and photos. Looked at your website. Your work looks great Saved it for when I get to that area
Thanks again
