Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-05-2017, 01:22 PM   #1
mag c10
mag c10's Avatar
71 Steering Column Wire Identification
Can anyone identify this wire? I am changing my instrument panel from lights to gauges, and when I removed the original panel, this wire was just loose back there. I'm not sure if I pulled it out of something, or if it was already loose. It appears as if it is separate from the turn signal wiring. The steering column is out of a 71, I believe.
Thanks in Advance!
Mark
1968 c10 stepside
1948 GMC
1969 Chevelle
mag c10 is offline   Reply With Quote
Old 12-06-2017, 12:09 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 71 Steering Column Wire Identification
Check your turn signal harness for a black wire which goes into the column for the horn button. It could be a separate wire someone wired in for that. You may also have the fiber optic line for the shift indicator light but the picture you have looks like some kind of switch on the end.GM went to a regular wire for the indicator light but I can't remember what year.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-06-2017, 11:20 AM   #3
mag c10
mag c10's Avatar
Thank you for your reply. I think I will pull the steering wheel, and trace out where it goes.
Mark
1968 c10 stepside
1948 GMC
1969 Chevelle
