04-05-2009, 02:33 PM | #1 |
Rocker box pictures
I am looking for some pictures of the stock rocker boxes on a 1970 blazer. The PO of my truck was an amature welder, and it looks like he took some liberties to strengthen some spots, and "create" his own panels. I am looking for pictures of the stock ones so I can compare them to mine and decide if I can just remove some of his handiwork, or if I need to get new ones.
04-05-2009, 07:12 PM | #2 |
PROJECT 7DEUCE
Re: Rocker box pictures
Top or bottom? The bottoms should look like snow sleds..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-06-2009, 12:26 AM | #3 |
I don't know if this gives what you need, but it's what I've got of mine so far.
04-06-2009, 12:28 AM | #4 |
The bottom lip you see is the pinch weld(outer to inner), other than that they look like loonngg shoe boxes.
04-06-2009, 05:51 AM | #5 |
Phat Tony, good pics but he's looking for rocker box pics, not torsion box pics...at least that's what he asked for anyway.
Jimmyfloyd, show us whatcha got to work with. Here's a few of a stock outer rocker for ya, if you need or want more just ask but be descriptive. I have pics of any & all stages from rip-n-tear through install. |
04-06-2009, 07:30 AM | #6 |
vtblazer, the rocker box and torsion box are the same thing.
http://www.gmcpauls.com/pictures/blazerrockerbox.jpg |
04-06-2009, 07:37 AM | #7 | |
You just posted a link to a set of replacement TORSION BOXES. Don't believe everything you read, if GMC Pauls is calling those parts rocker boxes, they're wrong. Trust me, I know the difference here and now, so do you. Last edited by vtblazer; 04-06-2009 at 07:39 AM. |
04-06-2009, 08:53 AM | #8 |
Rocker boxes are the same as torsion boxes except that very few people call them torsion boxes, you posted a picture of rocker PANELS.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery Last edited by 69-72; 04-06-2009 at 08:55 AM. |
04-06-2009, 09:44 AM | #9 |
I assumed rocker "boxes" were the assembly of inner structure and outer rocker panel.
04-06-2009, 11:13 AM | #10 |
hrm... Mine don't look like that exactly (or not at all) looks like I had a happy home welder working on mine before. Ugh.
Will get pictures later. |
04-06-2009, 12:22 PM | #11 |
urban fourwheelin
that what I thought as well.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
04-06-2009, 12:23 PM | #12 | |
There are THREE main pieces that make up the structure that keeps the door openings from sagging when the hard top is removed. Working from the outside in: 1) Outer rocker 2) Inner rocker 3) Torsion box ALL different, ALL separate and ALL necessary. I posted a pic of a replacement pair of TORSION BOXES. |
04-06-2009, 12:35 PM | #13 |
urban fourwheelin
this thread is confusing.
04-06-2009, 01:03 PM | #14 |
I haven't been inside a blazer rocker yet, I'm thinking the outer rocker(same as a truck) has an inner rocker(same as a truck) that is attached to the larger structure(box), yes?
04-06-2009, 01:19 PM | #15 |
Rods
not realy vt laied it out. as per fsm and not some sales ppl at some store. outer and inner. and torsion. if its was a rocker box as a standard part woulnt you think all truck would have them.... hmm somthing to consider.
04-06-2009, 01:55 PM | #16 |
No, I wouldn't think a truck would have them, a truck has a roof and rear cab structure to keep the a and b pillars from spreading.
04-06-2009, 02:14 PM | #17 |
Rods
THAT is the point i was making
04-06-2009, 02:34 PM | #18 |
Rods
the outer is the same there are some minor changes on the inner.
04-06-2009, 05:04 PM | #19 |
New Member
Who's to say it's not Rocker Panel, Inner Rocker, and Rocker Box.
04-06-2009, 05:13 PM | #20 |
New Member
Torsion: the process or condition of twisting or being twisted.
So technically they would be anti-torsion boxes. Just having some fun, not trying to make anyone mad. |
04-06-2009, 05:26 PM | #21 |
SKINNY TIRES RULE!
I've heard the terms torsion boxes and rocker boxes used to describe the same thing hear on the board - what VT posted in #7. For instance, WES has the same photo posted on his site and he calls them Rocker Boxes - http://classicheartbeat.com/catalog/...er%20Boxes.htm.
"You like potato and I like potahto, You like tomato and I like tomahto Potato, potahto, Tomato, tomahto, Let's call the whole thing off"
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-06-2009, 05:30 PM | #22 |
Rods
WES can call them what he wats but as for the Factory assembly manual. they are torsion.
04-06-2009, 05:31 PM | #23 |
C`mon guys,if you don`t know what you are talking about please listen to those that do.Just because you`ve been hearing parts called the wrong name doesn`t mean when you hear the right name it`s wrong.How can anyone help if no one listens?This board was made great and will continue to be by being a friendly place where we all can learn what we don`t know from those that do.If improper terminology goes unchecked it will destroy the point of different names for different items and no one will know what the other is saying.We all have names,right?When we`re in a crowd it helps narrow down who is being addressed by using the proper name.
The unigue to full top K/5s(remember Jimmys?) part who`s purpose is to give reienforcement to compensate for the strength lost when going topless is known as a torsion box.That`s what they are,were,and always will be. Vtblazer "has" been inside a rocker box and so have I,as well as torsion boxes.I consider them a part of the floor structure (stiffener).They aren`t an outer body piece.A pickup or Blazer can have rotted rocker boxes w/o effecting the structure.Once the torsion boxes get soft your doors start moving.I`ve seen restored K/5s with no torsion boxes.That`s fine as long as the top stays on and minimal body twist.The top will crack in any serious off road action with the t-boxes gone.Some of us can vouche for that. so,as said above from the outside in: Outter rocker Inner rocker Torsion box Can we all agree to agree?
04-06-2009, 05:35 PM | #24 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
04-06-2009, 06:20 PM | #25 |
Here is a shot of the items on a blazer/jimmy
These are all connection and important to the integrity of the body |
