03-22-2018, 07:10 PM | #1 |
Cam for 350
My son just gave me an Elgin E923P and a set of lifters. 350 with 041 heads, headers, edelbrock performer and a holley carb. What is ya'lls opinion on this cam. Think he has had it for years although it is new.
03-22-2018, 07:18 PM | #2 | |
Re: Cam for 350
Perfomance Year: 1955-2002 Make: Chevy Engine: 262-400 SBC Camshaft Type: Hydraulic Flat Tappet Intake Valve Lift: .420" Exhaust Valve Lift: .443" Advertised Intake Duration: 270° Advertised Exhaust Duration: 280° Intake Duration @ .050": 204° Exhaust Duration @ .050": 214° Lobe Separation: 112° Intake Centerline: 107° Firing Order: HL-1817 Quantity: Sold As Each pretty tame cam shaft @50 is small Last edited by hjewell2; 03-22-2018 at 07:20 PM. Reason: spelling |
03-22-2018, 07:21 PM | #3 | ||
"I ain't nobody, dork."
Re: Cam for 350
Specs look like a decent cam with good low to mid range power. Run it with a stock converter and see what happens.
What Holley carb? You'll not want more than 600 cfm's. Maybe 650 cfm's at max. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-22-2018, 07:40 PM | #4 |
Re: Cam for 350
It's in a 72 C20. Pretty old cam probably better cams out there though. Problem is I don't really know what is in this engine. As I just got the truck. May just wait until I pull it to see what it really is. I looked at the specs and sounded like a good truck/Rv cam.
03-22-2018, 08:03 PM | #5 |
Re: Cam for 350
That's the same as the Edelbrock Performer cam and I just bought the Summit branded one with same specs for my kids Jimmy project. Should be a good increase over stock but still compatible with stock converter and carb. What they used to call an RV cam.
We are running a Performer intake with remote choke JET Q-jet, Skip White HEI, and a set of Speedway Motors 2 1/2" 'vette manifolds. Waiting on a Claimer style oil pan with windage tray and scraper along with trap doors before we screw it back together.
03-22-2018, 08:03 PM | #6 |
Re: Cam for 350
same as Edelbrock 2102-
https://www.summitracing.com/parts/edl-2102 |
03-23-2018, 12:14 PM | #7 |
Re: Cam for 350
I've seen those numbers for a cam. LOL I just bought it.
03-23-2018, 09:49 PM | #8 |
Re: Cam for 350
Definitely have to see what you have now but, that cam will give a little more low end torque and be done around 5000rpm if that.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
