Old 01-01-2018, 08:53 PM   #1
6768chevylover
6768chevylover's Avatar
No spark, I'm lost
Have an msd coil, pro billet dist., msd 6al box, street fire wires and autolite spark plugs. I had it running one day and it died on me in the drive way. Ended up being msd box went bad. Bought a new one and still won't start. Checked coil and plug wires and they are with in specs. Swapped out the mag pickup in dist. and is with in specs.. I still have no spark through the wires. I have power through the coil by nothing after that. Any ideas cause I'm lost? Its a 350 and I have grounds from engine to frame and battery. Thanks for any help
6768chevylover is offline   Reply With Quote
Old 01-01-2018, 09:52 PM   #2
Hollow65
Hollow65's Avatar
Re: No spark, I'm lost
Check the box. They're a common problem, that being said I am running the same 6al for the last 20 years. Win some lose some. My bet is the box.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 01-02-2018, 12:04 AM   #3
Captainfab
60-66 Nut
Since you have what amounts to a complete MSD ignition system, I would be contacting MSD's tech dept.
Old 01-02-2018, 02:49 AM   #4
kwmech
I'd pull all that garbage out and get an HEI built by DUI
Old 01-02-2018, 02:28 PM   #5
6768chevylover
tried using a distributor from my blazer that I know that runs and im getting the same issue, no spark at the plug end... could it be the plugs even though they are within specs according to msd?
Old 01-02-2018, 02:48 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Within specs how? No idea how you wired this up, so hard to trouble shoot via internet.
I have been using MSD 6A and 6AL boxes since the 80's and have never had one fail. But if hooked up wrong you can fry one pretty easy.
Do you get spark to the plugs without the box?
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-02-2018, 05:03 PM   #7
6768chevylover
No I do not. I've had an msd box on my truck for alittle over 10 yrs. When it went bad I hooked up the new box the same as the old msd box.. specs as in according to msd you should have 500 ohms per foot(street wires) on plug wires. Every wire is within there specs..
Old 01-02-2018, 05:59 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would guess a coil issue. Never messed with MSD stuff though.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-02-2018, 07:55 PM   #9
6768chevylover
Its not the coil. I've tried buying a new one and hooked it up. Still doesn't work. I'm bringing coil back to store..
Old 01-03-2018, 10:54 PM   #10
Hollow65
Hollow65's Avatar
Any luck with this issue?
