Old 05-31-2017, 10:18 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
1957 Chevy Grumman Front Disk Brake Conversion
I usually stay on the 60-66 side but recently picked up a 57 Chevy Grumman van and was wondering what is the best way to convert the front to disk brakes.
Is the van front axle the same as a 3/4-1 ton truck axle?
Any good disk brake kits?
I want to keep the stock 19.5" Wheels.
I found this bracket kit. Any opinions on it? Will it push the wheels out to far?
http://www.thehollisterroadcompany.c...converion.html
I have a 2003 Chevy 2500 van rear axle with disk brakes and 3.73 gears so just need to figure out the front.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 05-31-2017, 11:49 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1957 Chevy Grumman Front Disk Brake Conversion
Send me a picture of the front hub. wheel off. and I'll tell you if t will work
Old 06-01-2017, 10:37 AM   #3
Classic v6 GMC's
Okay I will take some pics today.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-01-2017, 09:12 PM   #4
Classic v6 GMC's
Here are some pics
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-01-2017, 09:15 PM   #5
Classic v6 GMC's
Pics
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-01-2017, 09:45 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
That hub uses our SRW kit. Its a standard single rear wheel front axle. On the dually truck there is an extended hub that sticks out about 6" from the drum.
Old 06-01-2017, 11:28 PM   #7
Classic v6 GMC's
Okay thank you for the reply. Before I purchase I need to do my home work on the other parts I will need.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 01:08 AM   #8
MARTINSR
MARTINSR's Avatar
Why do you need the discs? Again, I have to ask the question. Unless you are driving a lot on winding mountain roads you do not need disc brakes.
Forget all the "modern highway" BS you don't need disc brakes unless you are driving it on windy mountain roads or something like that where the drums get overheated.
Just normal driving you don't need them.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-02-2017, 10:32 AM   #9
Classic v6 GMC's
Brian
Well I could get by with the drum brakes but I want to pull a trailer and drive anywhere (Through Colorado and Arizona) with out having to worry about it. The brakes need redone anyway and the rear axle already has disk brakes so might as well upgrade the front.
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 12:30 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Brian
The main reason for disc upgrade is drums are getting non existent. Below 1951 I doubt you'll even get parts for 3600 3800 other than wheel cylinders and seals. It can take weeks to months to find new drums if yours are not cutable. You can find some 3600 fronts but 14" rears are longer available anywhere.
The safety enhancements of disc brakes over drums are well known. The main one is if an outer wheel bearing fails on these trucks the wheel does not come off if its a disc brake. Disc brakes stop better with less maintenance, They don't fade in weather like drums and with the 2003 up parts this kit uses you can replace them in 10 years if you need to. Towing with a big van like he has its just a plain smart decision. Keeping up with traffic I one thing but you also need to be able to stop with traffic.
Old 06-02-2017, 12:46 PM   #11
_Ogre
_Ogre's Avatar
pics or it never happened
shop air compressor timer
Old 06-02-2017, 01:12 PM   #12
MARTINSR
MARTINSR's Avatar
Andy
I hear you, yeah, that is a different story. I just have to ask the question some times I hear the craziest reasons to put discs on and they simply aren't a MUST as some people have been brain washed to think.
Brian
1948 Chevy pickup
Old 06-02-2017, 04:38 PM   #13
dsraven
hey Brian, have you ever had to hit the brakes after one wheel goes through a big puddle, or both for that matter. not as good as discs plus they tend to pull. if it was me it would be discs already. haha
Old 06-02-2017, 05:06 PM   #14
MARTINSR
MARTINSR's Avatar
I have been driving for 40+ years, too many miles on drum brakes to count. I have never had anything happen that disc brakes would have somehow solved. That black rubber thing that is on the floor under the steering column that activates the brakes and the long black rubber thing that adjusts your speed mean a LOT more than the brake pads or shoes do.
I have to ask, what happened 40 or so years ago that changed everything? 40 years ago about 95% of the cars on the road were drum, it wasn't that many years before, 1970 or so where about 99.9% of the cars were drum. How did we survive? There must have been crashes on every street every day. Nope, there weren't, how in the hell did we survive.
Brian
1948 Chevy pickup
Old 06-02-2017, 06:08 PM   #15
MARTINSR
MARTINSR's Avatar
Listen guys, let me make this clear. I understand there is often a need for upgrading the brakes, of course there is. In this case, he plans on towing a trailer, driving on windy roads a lot, high speed on the interstate, that sort of thing. Of course there can be a need for it, as I agreed with the original poster told me why he wanted them.
But it is WAY overblown as to the need for disc brakes. Every time I hear someone say "modern highway" I want to puke, first off about 90% of the roads in America where made before disc brakes were "the thing."
But it really depends on how the car/truck will be driven. I drive a car with 9" drum brakes every day, they don't even have self adjusters and it has a single reservoir master cyl even. I maintain them checking them every 5-6 thousand miles, I it's not a big deal. It stops amazing good, I was blown away the first time I had a real life "panic stop," I was amazing how fast that sucker stopped.
But I drive it, get this, like it has drum brakes, what a thought. I drive it conservatively. Not slower, just simply leaving more room than the average driver has gotten accustomed to. I feed my family with car wrecks, people with all the disc brakes and abs and all that have paid for my home and feed my family, people have adjusted to drive the way they do and honestly get in more wrecks than years ago.
When I see things that don't need it, people get all freaked out and spend money and change something that doesn't need to be, I am going say something. Wish I had gotten to the guy I saw last Goodguys show before he RUINED this virgin garage find 58 Impala Conv with a tri-power 348. OMG it was a virgin car original paint and all, and he put power disc brakes! Those were the only shiny new parts on the car! Geeeez
But yes, there is a place for discs, of course there is. We just need to stop the brain washing that is MUST be done. Let the guy who doesn't need them go out with a smile on his face with his old car or truck like I do every day.
Brian
1948 Chevy pickup
Old 06-02-2017, 10:09 PM   #16
Classic v6 GMC's
Brian
Yeah I should have put my goals for the truck in the first post.
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 10:14 PM   #17
Classic v6 GMC's
Here are a couple pics of the master cylinder.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 10:19 PM   #18
Classic v6 GMC's
Here a couple pics
When I am ready to start working on it I will create a build thread.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 10:21 PM   #19
MARTINSR
MARTINSR's Avatar
Andy
No biggie, that rig is AWESOME! I want to see that build for sure!
Brian
1948 Chevy pickup
Old 06-02-2017, 10:25 PM   #20
Classic v6 GMC's
Brian
Thank you, it's a neat truck! Hope to start working on it in a couple months.
Andy
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-02-2017, 10:48 PM   #21
dwcsr
Hollister Road Co.
dwcsr's Avatar
It has two rods that operate the master cylinder. You may have to get a pedal bracket for a pickup and mount it to get a vac booster on and in the right position for the dual piston disc brake to operate properly. Its doable so when ever your ready let me know
Old 06-02-2017, 11:16 PM   #22
Classic v6 GMC's
Okay Thanks. I will.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 06-03-2017, 12:58 AM   #23
MARTINSR
MARTINSR's Avatar
It looks like the windshield is made up of 6 pieces? A flat piece at the center and then a curved one with the flat one on the sides?
If that is the case those flat ones will be easy to change. The curved ones are a while different story but if you had the flat ones new it would be what you are looking threw most of the time and it would make a big difference.
Brian
1948 Chevy pickup
Old 06-03-2017, 01:18 PM   #24
_Ogre
_Ogre's Avatar
those curved glass pieces are probably rare as hens teeth
thanks for posting up the pics, that body looks pretty clean
Old 06-03-2017, 01:45 PM   #25
dwcsr
Hollister Road Co.
dwcsr's Avatar
I saw a few videos on how to make those out of Lexan. Seemed to be moderating easy but time consuming
