Old 01-11-2016, 11:55 AM   #1
Lugnutz65
Lugnutz65's Avatar
Engine run stand and 230ci running.
I thought I'd share a success story. I bought a recently rebuilt (4K miles ago) 230ci from a guy who did a V8 swap. Looks brand new. I decided that building an engine run stand would be fun and useful. Fabrication took about 4 weeks of my free time and I used plans I bought on eBay. Fired that sucker up for the first time last night. WooHoo! Here's a video and some pics.
http://youtu.be/D6SZjZC-k_M
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 01-11-2016, 01:00 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Engine run stand and 230ci running.
I've been keeping up with your posts since you bought the engine. Sounds good and a few adjustments to the carb, timing, maybe an HEI, it ought to purr like a kitten.
Awesome stand. I wouldn't mind building one like it if a 350 will go on it also. What plans did you get?
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-11-2016, 01:27 PM   #3
Lugnutz65
Lugnutz65's Avatar
At work now but I'll post a link to the eBay plans and I'll also send you the designer's email in a PM. The run stand is actually designed for SBC and BBC too. He said i'm the first person he'd seen to put a L6 on the stand.
I will use an HEI and the rebuilt carb from my other engine. I have a Weber progressive 32/36 that I might try too. That's the main reason I built this stand. I personally own 3 inline engines that I need to test.
Old 01-11-2016, 10:07 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
That's awesome! Checked out the new video...sounds healthy! I am interested in the stand plans to.
Old 01-11-2016, 10:28 PM   #5
Lugnutz65
Lugnutz65's Avatar
Thanks for the comments. It was fun to build, but also a lot of work. It will outlive me and I can let my friends use it.
HERE is a link to the plans on eBay. I had to make small modifications. You'll need a good welder. I like the telescoping legs that add stability. MOST of all I like that it stores in a vertical position so it takes up very little floor space when not in use. These pics might give you a feel for how much work is involved.
Sorry about the sideways pics but it has something to do with my new computer. Haven't figured it out yet.
Old 01-11-2016, 11:27 PM   #6
DD1
That's pretty cool! Nice job on the stand and getting the engine running. I really like the gauge panel you setup.
I just started a 350 engine that I had rebuilt 2 years ago, except mine is on the frame (no cab or anything). I think yours started up better than mine did; it took a few tries and correcting several mistakes.
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 01-11-2016, 11:37 PM   #7
Lugnutz65
Lugnutz65's Avatar
I mounted my engine in the frame and did what you did the first time. My truck is now a driver and I really don't want to swap engines without checking out things. PLUS, I have 2 more engines to test on the run stand. Possibly even a 3rd engine. It just made sense to build a run stand and it was a fun project with a well thought out design.
Old 01-13-2016, 11:32 PM   #8
DD1
How do you have the amperes gauge wired up? What are the terminals connecting to?
Darien
1971 C10 LWB
Old 01-14-2016, 12:17 AM   #9
Lugnutz65
Lugnutz65's Avatar
The amperes gauge is not hooked up. I really don't intend to for this engine because I'm gonna use the alternator from another engine.
Old 01-14-2016, 09:25 AM   #10
Lugnutz65
Lugnutz65's Avatar
About the gauges. Since this was just a run stand that might sit around and not be used for months at a time, I decided to go cheap. I bought the Harbor Freight triple gauge set. It was $15 out the door with a coupon. I didn't want the amperes gauge but installed it anyway. The big tach was a donation from a friend.
The HF gauges are OK for the price. Mechanical oil pressure. Capillary tube for the water temp. Both seem to work fine for the purposes of a run stand. I want to add a throttle cable so that I can maintain a steady idle at certain RPMs if needed.
Old 01-14-2016, 12:06 PM   #11
Marv D
Registered Truck Offender
Marv D's Avatar
Not trying to 'one-up' anyone but ... WHY no radiator or fuel system, battery....???
I built a 'break-in' stand to do engine breakin and testing (just WISH it had a pump on the back of it ) I mean without a fuel supply and pump,,,, radiator and cooling fan your pretty limited in how long you can run. Not AT ALL what you'd want if your were inclined to do a flat tappet motor.
Won't contaminate the thread with pictures but,, most of the 'material' to make the frame and casters were,, umm 'gathered up' from a something left in an alley,, and added some 1-1/4" tubing to support stuff,, slaped an old Mallory ignition box on it for giggles and to support whatever ignition happens to be used. But it can handle most any motor I want to test fire or break-in.
http://www.small-block-chevy.com/ima...83_Jan1_16.JPG
http://www.small-block-chevy.com/ima...kin_stand2.jpg
http://www.small-block-chevy.com/ima...kin_stand3.jpg
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-14-2016, 12:13 PM   #12
Lugnutz65
Lugnutz65's Avatar
I think you missed seeing the video in the first post. I have a radiator, battery and fuel tank. I'm gonna change to a different fuel tank next run. This stand is intended to be used for break ins as well as other testing. Check out the video.
Old 01-14-2016, 10:39 PM   #13
Marv D
Marv D's Avatar
I definitely did skip over the video. YUP makes perfect sense now.
