05-24-2020, 07:32 PM | #1 |
Finding TDC Am I wrong?
Got into a discussion with some fellows about finding tdc to drop a distributor in on a small block. They were of the opinion you had to either physically see the piston at the top or somehow feel the air coming out of the spark plug hole. I have always just had the valve cover off and if the timing mark was on zero and both valves were closed on cylinder #1 you’re there. That’s the way I’ve always did it but then it’s not like I drop distributors in twice a week. They called BS and that I must have gotten lucky if it worked for me. Who’s right?
05-24-2020, 08:00 PM | #2 |
Re: Finding TDC Am I wrong?
You're right. The TDC mark goes around twice for each cycle of combustion. While turning the balancer you watch the intake valve open, then it goes shut and the mark lines up. Boom...TDC. if you keep turning, the exhaust valve opens and shuts and the mark comes around again.....not TDC.
Feeling the compression with your finger works too but is far easier with two people and of course negates the need to pop a valve cover. |
05-24-2020, 08:13 PM | #3 |
Both ways work. The finger on the hole is an easy way to do it with out taking anything apart. Here is my procedure. Hook up the remote start button, pull the number 1 plug, bump the motor over with a finger or a rubber plug on a stick and listen for air while looking at the timing mark. When it is up I drop in the distributor. This assumes the mark on the balancer is good. Finding true TDC is a entire different process.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-24-2020, 08:52 PM | #4 |
Who Changed This?
Back in the day, I had a whistle that screwed into the spark plug hole. When you came up on #1 plug, you were sure to know. ♪ Chirp! ♪
05-25-2020, 11:57 AM | #5 |
05-25-2020, 12:09 PM | #6 |
[QUOTE=Steeveedee;8745613]Back in the day, I had a whistle that screwed into the spark plug hole. When you came up on #1 plug, you were sure to know. ♪ Chirp! ♪[/QUOTE
You can make a whistle from an old spark plug. Just knock the porcelain off it and drill out the centre electrode. |
05-25-2020, 01:27 PM | #7 |
But Found Her 25yrs Later!
After I know it's on the compression stroke by using one of the methods above, I put a length of coat hanger wire in the spark plug hole, and slowly turn the engine with a wrench on the balancer. Turn it back and forth watching the wire go up and down and then stopping when it is Dead Center at the Top.
