Old 02-12-2018, 01:27 PM   #1
applebmw
Removing inner fenders Question
Any one remove inner fenders for paint? I have motor pulled, would like to remove inner fenders to get repainted. They come out from underside with ease ?
applebmw is offline   Reply With Quote
Old 02-12-2018, 01:53 PM   #2
Jason Banks
Jason Banks's Avatar
Re: Removing inner fenders Question
Relatively easy to get out. You either have to jack up the truck or remove the wheel. Probably easiest to just remove the wheel. There are several bolts and many will be stuck or need some type of persuasion...but, if you pulled the motor you can handle the inner fenders
Jason Banks is offline   Reply With Quote
Old 02-12-2018, 02:42 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
All the ones I've taken out the nuts which are a clip on style with a molded nut made into them always break and free spin with No way to put pliers to hold them. I've had to use a cut off wheel and cut the head off. If you decide to remove them get some good penetrating spray and spray them several times before you even try. P. B blaster works very well. P.s this all depends on how old the clips are and when the last time they was off. Good luck.
Jcfcamaro is offline   Reply With Quote
Old 02-12-2018, 04:21 PM   #4
cebra
Active Member
I broke all but 1 of my j-nuts but they were super easy to drill out. Napa sells them, if you do a search you can find the nuts and the bolts part numbers.
cebra is offline   Reply With Quote
Old 02-12-2018, 08:31 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Use new bolts/Jnuts to put it back together. Most vendors have them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-13-2018, 09:10 AM   #6
applebmw
Thanks guys, they came out easier than I thought.
Old 02-13-2018, 11:26 AM   #7
brown7373
brown7373's Avatar
So the inner fenders rotate outward, rather than inward toward the engine? I thought I would have to remove the bumper and fenders to get the inner out. And the right can be removed with the engine in the truck? The front of my right inner is all rusted and corroded off, probably from a battery leaking down.
brown7373 is offline   Reply With Quote
Old 02-13-2018, 12:08 PM   #8
Tiger Joe
inner fenders drop out from the bottom. I have gotten them out with the tire still on, buts its easier to just remove the wheel.
there is no need to touch the engine, bumper, anything other than whatever is bolted to the inner fenders themselves.
Tiger Joe is offline   Reply With Quote
Old 02-13-2018, 12:21 PM   #9
Jcfcamaro
Jcfcamaro's Avatar
Good deal!!!
Old 02-15-2018, 10:52 AM   #10
brown7373
brown7373's Avatar
Yes, thanks from me too. I will order an inner fender today!
Old 02-15-2018, 01:02 PM   #11
rsavage
rsavage's Avatar
See if you have a vendor near by where you can pick up the inner fender. Shipping on sheet metal is very often truck freight and the shipping will cost more than the piece.
1961 C1 Corvette
70 GTO convertible numbers matching 400, 4 speed
69 Blazer 4 WD. Latest restoration project
2018 Durango 392 Hemi SRT 0-60 4.4 sec, 12.9 1/4 mile
rsavage is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
