Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-23-2019, 11:33 PM   #1
SunSoaked
SunSoaked's Avatar
Relay mod 4 headlights- circuit breaker?
I'm in process of putting the headlights on relays. I'm pretty sure the factory has a circuit breaker in the circuit. So is this feature lost in the conversion? It would only be protecting the low power control wires to the relays. Should I add breakers on the load side of the relays? Seems goofy since the relays are within a foot of the battery now.
SunSoaked is offline   Reply With Quote
Old 01-24-2019, 10:46 PM   #2
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Relay mod 4 headlights- circuit breaker?
If you tied into the main wire at the battery past the fender mount you have the fusable link in the wire already but if you tied straight to the battery I'd put a 40 amp breaker in line.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-25-2019, 02:52 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here's two diagrams to help you out.
The first doesn't give a value but a 20 to 30 amp fuse or circuit breaker in each circuit should be plenty.
The second shows a 20 amp fuse.
Using the Oms law calculator, if you are pushing 100 watts per headlight at 14 volts, you will have 9.8 amps in each light, so double that is 20 amps for the circuit. If you used a 30 amp fuse in each circuit you would be safe.
Name:  headlight relay mod for chevy.gif
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-25-2019, 09:55 AM   #4
SunSoaked
SunSoaked's Avatar
As always, thanks VetteVet!
Old 01-25-2019, 01:07 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You're welcome but I just illustrated what Andy said.
VetteVet
Old 01-25-2019, 01:15 PM   #6
SunSoaked
SunSoaked's Avatar
I wired it just like the 2nd diagram except I used 16 guage fusible link instead of fuses. Funny how Napa sells fusible links with a ring terminal for $7 or you can buy a spool of link for a dollar more. Lol
Old 02-05-2019, 03:50 PM   #7
damnyankee36
On that second diagram, wouldn't you rather consider using circuit breakers instead of fuses for safety purposes? At least if an overload occurs you won't completely lose your lights.
damnyankee36 is offline   Reply With Quote
Old 02-05-2019, 05:09 PM   #8
SunSoaked
SunSoaked's Avatar
The breaker is in the light switch. After the mod, it only controls the relays. The hi/low are now on separate circuits. If one shorts, just hit the dimmer switch. I used fusible link cause it's more reliable and less clutter.
The difference is night and day I might add with the H4 bulbs and relay mod.
Old 02-05-2019, 06:11 PM   #9
beaterku
beaterku's Avatar
Here is how I have wired them in the past. Getting ready to wire my truck this way as well. I put a 30A fuse/breaker on the power feed. Wiring this way will not allow the low and hi to be on at the same time.
-Nick
My 72 SWB build
My YouTube channel
beaterku is offline   Reply With Quote
Old 03-04-2019, 11:41 AM   #10
dfosh
Is this for a GMC ? Thanks
dfosh is offline   Reply With Quote
Old 03-05-2019, 09:34 AM   #11
SunSoaked
SunSoaked's Avatar
Uhhhhhh....no.
Old 03-06-2019, 01:08 AM   #12
dmjlambert
dmjlambert's Avatar
On a 4-headlight system all you do is run extra wires to power the inboard high beam lights in parallel to the high beam filament on the outboard hi/lo beam bulb. So the relay wiring is the same if you have wired the bulbs together.
Old 03-06-2019, 11:41 AM   #13
dfosh
Thanks for the info . I just miss read the question when it was posted.
Old 03-09-2019, 08:50 PM   #14
Woodsloafer
Junior Member
Subscribed
Woodsloafer is offline   Reply With Quote
Old 03-09-2019, 09:26 PM   #15
beaterku
beaterku's Avatar
I used the wiring diagram above to wire up my hi/low relays. One feed wire running to a 30amp fuse. You can see the heavy red wire jumping from one relay to the other.
My 72 SWB build
My YouTube channel
Old 03-10-2019, 01:35 AM   #16
dmjlambert
dmjlambert's Avatar
beaterku that is some really neat wiring. Better than factory.
Old 03-10-2019, 09:02 AM   #17
The Rocknrod
MCPO USN Ret.
The Rocknrod's Avatar
Could fused relays work? https://www.ebay.com/itm/12V-DC-40-3...MAAOSwuLFZw09j
The Rocknrod is online now   Reply With Quote
Old 03-10-2019, 03:05 PM   #18
beaterku
beaterku's Avatar
Thanks. I am a bit anal retentive. I also have 3 relays on the pass side for fans and fuel pump.
My 72 SWB build
My YouTube channel
Copyright ©2000 - 2020, vBulletin Solutions Inc.
