Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-25-2019, 05:16 PM   #1
camarozl1
Ac heater box
Hi
I have a 72 c20 AC truck
Looking for the ac heater cable routing diagram.
There are 3 cables and i cant figure out there orientation.
camarozl1 is offline   Reply With Quote
Old 03-04-2019, 09:20 AM   #2
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Ac heater box
Here you go.
from the bottom lever the longest goes through the firewall out to the mixture flap and inside to the temp control lever usually on the bottom
the second longest goes from center lever to the flap control in the center section of the ac box that flap also hits the switch thats inside the airbox that turns on the ac compressor
the shortest goes from top lever(which controls defrost and floor heat) to the part of the ac box located right below the ac control to control the defrost.
hope this helps
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-04-2019, 09:35 AM   #3
Andy4639
Orignal Goof member
Andy4639's Avatar
If you look at the face plate and think about it for a few seconds it is pretty obvious where they go. Now this isn't me being smart but just letting you know.
#1. Top lever connects to the bottom down at you feet the one you can see while driving. This is the one that makes the air blow out the bottom are through the defroster vents.
#2. Middle cable is the AC controller cable and heater, it connects on the back side of the box on passenger side. It activates the AC clutch also on the back of the box when AC is selected.
#3. Bottom one goes out to the motor compartment and hooks to the flapper in the cowl to let fresh air in are not.
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
