Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-04-2019, 12:18 PM   #1
flemingo
1970 c10 voltage regulator wiring
I removed my voltage regulator to repaint and clean up my radiator core support. I committed a crime. I did not write down the wiring sketch. Now everything is installed and I am only getting 12.4 volts at the alt. when running. Is it a ground problem or something else?
flemingo is offline   Reply With Quote
Old 03-05-2019, 05:16 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1970 c10 voltage regulator wiring
This might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=601025
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-06-2019, 12:04 PM   #3
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: 1970 c10 voltage regulator wiring
You may just need to scrap a small amount of paint off to get a good ground where the regulator is mounted.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
