02-15-2013, 06:13 PM | #1 |
Bumper Guards: is there a L and R?
Hey all,
I was wondering if the bumper guards for the 63-66s are directional. Do they have a driver's and passenger's side. I found ONE at a swap. It is a little beat up, but, a stock original that I can probably knock the dents out of and use just fine. The thing is, it fits the drivers side of my bumper way better than the passenger. The "upright" also has a heavy angle to it. Is that stock or is mine that messed up? |
02-15-2013, 06:23 PM | #3 |
Re: Bumper Guards: is there a L and R?
Wow, then mine is tweeked!
Thanks. |
02-15-2013, 06:24 PM | #4 |
Check The Champ, Demonstrator
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
02-15-2013, 06:28 PM | #5 |
What's with the two part numbers?
02-15-2013, 06:38 PM | #6 |
I'll tell what's with the two part numbers, They AREN'T the same. I ran out and looked at mine quickly and they looked the same. After seeing the assembly sheet I went out and looked more carefully, and, sure enough, they are indeed a little bit different... Sorry for the "too quick" look.....
02-15-2013, 06:46 PM | #7 |
Thanks for going and double checking man. The two part number thing had me wondering. GM was pretty good about that sort of thing in those days. So, I am correct in that the "upright" has a slight twist to it? I thought mine looked too cleanly bent to have been done on accident. Mine has some impact dents from the front as one would expect, but, it would take a unique force to twist one of the towers. That's what made me think they are two seperate pieces. Well, what are the odds of finding a passenger side one now?!?!?!
02-15-2013, 07:04 PM | #8 |
They aren't really twisted as much as the inside edge that goes against the bumper itself is taller on the outside edge and shorter on the inside edge to compensate for the side-to-side curve of the bumper... if that makes any sense.
02-15-2013, 07:17 PM | #10 |
Those are accessory part numbers 985501 is the painted bumper guard and 985502 is the chrome guard
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-15-2013, 07:50 PM | #11 |
This is a set of NOS 63-66 front guards. Chevrolet was very good about marking these R+L if there was a r+l. These are not marked. I show ONE guard going to left or right side of a 66 bumper and the fit. I think your guard may be twisted ?
02-15-2013, 09:11 PM | #12 |
Notice in the accessory book accessory part numbers 985501 is the painted bumper guard and 985502 is the chrome guard . Also notice in the GM Parts book it says you need "2" instead of "R+L
02-15-2013, 10:08 PM | #13 |
Senior Enthusiast
The guards on my truck were NOS in the factory sealed box when I purchased them in 1992. One seems to fit better on one side than the other, but they are both identical.
There are actually two different factory installation sheets for the bumper guards. One shows them mounted over the factory bumper bolts, and the other shows them exactly 3” outboard of the bumper bolts. This is the instruction sheet that came with the guards I purchased. I don’t know which template GM produced first: And these photos show how tight they fit against my original bumper: As far as I know, the only difference between the 60-62 and 63-66 bumper guards is in the vertical spacing of the bolt holes, since the later frames are taller.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-15-2013, 10:59 PM | #14 |
Mark, its been my experience that the GMCs put them outboard of the bumper bolts so they don't cover up the “GMC” in the grille. I think Chevy put them over the bumper bolts. This would be a great topic ??? I feel its also the difference from Assembly line /Factory installed verses Dealer installed
02-15-2013, 11:20 PM | #15 |
Well, now I'll have to get some photos of mine and post them up. After reading what VPersh wrote I went home and looked at mine: he's 100% correct. There is no doubt a difference in the opening where the guard meets the bumper from one side of the guard to the other.
This dimension is also noticeably different. It looks to be about 5/16" larger from one side to the other. While mine is damaged from doing it's job guarding the bumper, I don't see any sign that it has been modified in any way. I do know for certain that it fits the drivers side much better than passenger, and I really don't think any of the damage done to it has anything to do with it's fitment. Kind of interesting. |
02-16-2013, 01:29 PM | #16 |
02-16-2013, 02:44 PM | #17 |
Senior Enthusiast
While I agree the guards look better outboard on the GMC trucks, (which is where I mounted mine) I note both instruction sheets refer to series 10-20-30 which are Chevy identifications. GMC’s models are identified as 1000, etc.
I’m thinking the outboard instructions probably came first because they are not dated. The other instructions appear to be dated 1962, which may have been a revision when GM decided it was too much trouble to drill the extra holes, or perhaps it caused warranty problems with the plated bumpers.
02-16-2013, 07:53 PM | #18 | |
02-16-2013, 09:08 PM | #19 |
Senior Enthusiast
Looking forward to the pics.
02-22-2013, 05:19 PM | #20 |
From the Chevrolet/GMC Parts Catalog, this is a page with the parts breakdown for the Accessory Bumper Guards. While it shows the different part numbers for the Chrome and Painted Guards and fasteners, it doesn't show a Left or Right. A Left Or Right application was separated by a single last digit. Right being an even number and Left an odd number. They must not have been available Left and Right as single units and came only as a pair, or , they are the same, both sides.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 02-22-2013 at 05:31 PM. |
02-23-2013, 11:20 AM | #21 |
In regards to the placement of the guards, I did alittle research in my 65 and 66 chevy accessorie sales fliers and they have pictures with two different layouts. It appears as though the general couldn't make up his mind. The photo with the blue truck with camper in the back is out of the 65 accessory flier and the others are out of the 66 flier. The ones in 66 are very wide apart wider than marks gmc. All very interesting info.
01-15-2019, 02:23 PM | #22 |
I was going through some old historical pics and found the GM Factory mockup for Guards. With this picture, there is no question where GMC wanted the guards to be installed.
http://s1299.photobucket.com/user/jb...23904108567829 |
01-15-2019, 02:42 PM | #23 |
cool informative thread ...
dont want to hear excuses, i want to hear solution(s) |
01-15-2019, 07:48 PM | #24 |
I saw a while back that one of the reproduction companies in their catalog (I forget which company) specifically mentioned that you couldn't mix reproduction bumper guards with factory bumpers, and vise-versa.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
01-15-2019, 10:38 PM | #25 |
1965 Chevy C10, 2005 4.8L/4l60
I think they all say the aftermarket guards are only for the aftermarket bumpers.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
Thread Tools | |
Display Modes | |
