07-20-2017, 12:47 PM | #1 |
wheel spacers
I've checked this site on wheel spacers and seem to find a lot but don't seem to find ones with the hub centric spacers.. Anyone know a good site to get these type of spacers?
07-20-2017, 01:02 PM | #2 | |
Re: wheel spacers
How thick of an adapter do you need? |
07-20-2017, 03:47 PM | #3 |
Re: wheel spacers
On the rear of my blazer the PO put a 1.5" spacer on the rear. I can't say I don't trust it since I have done some trailering with it in the past winter. I don't know any thing about it. Wanted to go down a half size to 1" . I like the look of the wheels equally spaced out..
07-21-2017, 04:21 PM | #4 | |
Re: wheel spacers
They might work in the rear, but if you use them up front they will increase the scrub radius of your front end geometry, as well as put additional stress on upper and lower ball joints. Increased scrub radius will make you feel more bumps in the road, and could cause your tires to rub at extreme turns. |
07-24-2017, 09:11 AM | #5 |
Re: wheel spacers
Thanks! I would never use these on the fronts. I actually had a wheel guy tell me to never do that.. Stuck with me ever since.
