Old 08-30-2021, 02:48 PM   #1
69Tom
69Tom's Avatar
deluxe weatherstrip - lock strip
So, about 8 months ago, as I needed a new windshield, I purchased and installed a new deluxe Precision weatherstrip/windshield gasket with new chrome lock stripping.
Well, fast forward after those months in the AZ sun, and the lock strip, once chrome looking, has turned an odd brown/rust color. In fact, it looks like the lock stripping has done just that - rusted. Except we don't get all that much rain here, and I'm pretty sure it's some kind of compound plastic.
Anyone else have this issue? And if so, did you find some chrome lock strip that doesn't do this?
I could see it happening over time, but after 8 months is pretty ridiculous.
69Tom is offline   Reply With Quote
Old 09-01-2021, 12:50 PM   #2
69Tom
69Tom's Avatar
Re: deluxe weatherstrip - lock strip
No one? I'm the only one with issues with this?
Old 09-01-2021, 01:29 PM   #3
Zachary17
Zachary17's Avatar
Had the same thing happen to my 82 after about a year
Zachary17 is offline   Reply With Quote
Old 09-01-2021, 02:07 PM   #4
69Tom
69Tom's Avatar
Thanks. I actually just gave my window guy a call and he said it happens to all aftermarket lock strip and recommended I use the black one (which I don't want to do). Anyone have any NOS chrome lock strip? haha.
Old 09-01-2021, 03:21 PM   #5
Pontiac1976
Pontiac1976's Avatar
I have some old GM that end up the same after sun and rain. I think the main thing is UV rays O2 in water get under the clear plastic. You can try to clear coat with UV clear 1or 2 thing coats on the strip after dry install.
or remove the plastic cover and clear it with UV clear 3 or 4 time let dry and install.
+ You may want to use a plastic flex agent in the clear.
Over the years had two GM deluxe weather strip-lock strips since my truck sit out side all year long in the sun/rain. They both turned. The less sun and rain they get the longer the last. But the rubber /plastic combo they used back then
is still what they use today.
Now Remember they want to sell them GM at the time, and the after market people.
DIY: most bang for the money longest lasting would be. The reg. black weather strip - lock strip could save you and you can paint the chrome or sliver strip then clear with UV clear
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 09-02-2021, 09:15 AM   #6
Wgesnerjr
Wgesnerjr's Avatar
I did the precision gaskets and chrome lock strip with a new windshield about 2 years ago. within 6 months the chrome strip started turning a light brown color that stood out like a sore thumb. Thought about looking for a better one but never got around to it.
Currently mine has turned almost a dark bronze color and is not standing out as much as before. At this point i am going to let it continue to change and see how bad it gets. If I find i don't like it, I will replace with a black one.
Ironically, the rear window chrome strip has not tuned at all. weird. Wish I could remember where I got that one.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 09-02-2021, 01:17 PM   #7
TKCR
TKCR's Avatar
Someone had mentioned this before, when there was discussion on this topic. The lock strip has a clear plastic protection film, to help with scratches I assume. But that film needs pulled/peeled off after installation. I can remember doing that myself on mine. In fact, I can remember thinking that there wasnít a film, because I couldnít hardly find an area to get it started to peel off. I was about to give up because I was convinced it wasnít on there. But my brother, who helped me, finally got it started. And then it all peeled off.
So this person was saying that is the reason why some of these lock strips look the way they do, because itís that plastic film that has baked in the sun, because it wasnít removed.
Old 09-02-2021, 02:43 PM   #8
69Tom
69Tom's Avatar
Interesting. So the plastic film on them is causing the issue then. Well, I'm not sure what happens when you try to remove a baked one. I'm guessing it's near impossible, so I'll just have to buy a new strip.
Old 09-02-2021, 02:43 PM   #9
69Tom
69Tom's Avatar
Yep! Exactly how mine looks. Guess we need to buy a new one and remove the plastic film.
Old 09-02-2021, 03:09 PM   #10
TKCR
TKCR's Avatar
I would assume once they are baked on, thereís no removing now. I just texted my brother, to see if he remembered that, when we did my strip. And he does, he said he remembered pulling it off. Now mine still looks good, itís been on there about 6-7 years now. Its not sitting out in the sun all the time, but it does see sun.
Old 09-04-2021, 12:57 PM   #11
Pontiac1976
Someone had mentioned this before, when there was discussion on this topic. The lock strip has a clear plastic protection film, to help with scratches I assume. But that film needs pulled/peeled off after installation. I can remember doing that myself on mine. In fact, I can remember thinking that there wasn’t a film, because I couldn’t hardly find an area to get it started to peel off. I was about to give up because I was convinced it wasn’t on there. But my brother, who helped me, finally got it started. And then it all peeled off.
So this person was saying that is the reason why some of these lock strips look the way they do, because it’s that plastic film that has baked in the sun, because it wasn’t removed.
Very Interesting info TKCR. I know I never took it off back then. But the one I think in storage I may take a try at that. the next time re place. Right now I'm just liking the blacked out look.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
