Old 03-26-2020, 06:25 PM   #1
CO71Blazer
Holley Sniper wiring
I've searched and searched until my eyes are bleeding but I haven't found my answer. Maybe my Google-Fu is just off...
I'm hooking up my Holley Sniper system in my 71 and wiring is not my strong suit. I have a Painless harness and according to Painless I can use their pink wire as switch power for EFI. But they also say to connect that same wire to the Batt terminal on my HEI. I asked Holley if I can use that as the connection for the Sniper pink wire. They just repeated the same, it has to be a clean power source.
Can I use this wire, it comes from the ignition via the fuse box, for my Sniper? If not, how are y'all connecting the pink wire on the Sniper?
Sorry if it's been beat to death, I just couldn't find the answer.
Thanks.
CO71Blazer is offline   Reply With Quote
Old 03-26-2020, 07:06 PM   #2
litebulblsc
litebulblsc's Avatar
Re: Holley Sniper wiring
If you really are worried about the clean power for the sniper- y off that pink wire so it runs to the distributor like normal, and use the other leg to trigger a relay to supply straight from the battery voltage to the Sniper.
litebulblsc is offline   Reply With Quote
Old 03-27-2020, 11:09 PM   #3
Blazerowner
Blazerowner's Avatar
Be sure all your plug wires are high quality when you get sorted out. I had noise from mine and it was havoc for the efi. As far as wiring a direct wire for the power from the battery seems to be the way to go. I’m sure some more people will chime in. I’m going off my old kit so there could be some changes.
Kirk
72 Blazer CST 4wd highlander
70 Chevelle Malibu
Blazerowner is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions Inc.
