Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-14-2017, 07:26 AM   #1
D13
D13's Avatar
Home brew W&G remover?
I was looking at W&G remover and it appears the 'water based' version is water, isopropyl alcohol, and acetone. In the aut industry we use straight IPA for most cleaning duties. I aasume the water is a voume carrier and the acetone is the flash agent (in school we used to use acetone to remove water from filter media before weighing). Is there any reason that a person couldn't home brew their own? The commercial stuff gets pricey when you start talking detailing frame parts with lots of little corners.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-14-2017, 07:52 PM   #2
MARTINSR
MARTINSR's Avatar
Re: Home brew W&G remover?
You are spraying a car with MANY hundreds if not thousands of dollars in primer and paint and clear, and the wax and grease remover is $25.....Hmmmmm
I'll let you think about that a little bit.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-14-2017, 11:27 PM   #3
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
^^^^ Yep
And out of curiosity how "expensive" are you talking?
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 11-15-2017, 07:27 AM   #4
D13
D13's Avatar
I'm spraying sandblasted trailer and truck chassis parts (frames axles etc) and power washed / possibly blassted manual transmissions and bell housings (well oiled thanks to the dirty diesel and bad rear seal on the 250) with 2 part epoxy followed by black cheap enamel. Surface finish is unimportant, but paint adhesion is critical for my dirt road winter salt dipped drivers. Plus I have a 120 bin parts cabinet that needs to be cleaned and painted.
I use brake cleaner for small parts with lots of grease (like starter braces and shifter parts) because the power spray lets it get into the little crevices. But at $3.50 a can on sale it gets real expensive real fast. I use W&G remover on the larger stuff where I can get it relatively clean first, and that seems to run $10-15 a gallon. I used to use straight acetone ($15 / gal) or denatured alcahol ($10/gal) but the W&G seems to be right in the middle of those for grease wash off and flash times. My current jug seems to be about 50% water.
Just asking. LOL. And no, when I did the base / clear on the minivan I used the right stuff, because finish was important.
1987 2 ton
Old 11-15-2017, 07:54 AM   #5
mongocanfly
mongocanfly's Avatar
I didn't know there was any "right stuff" for a minivan...haha
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-15-2017, 11:18 AM   #6
MARTINSR
MARTINSR's Avatar
Ok I'll give you a break. I still would just by the W&G remover, just the cheapest I could find.
Brian
1948 Chevy pickup
Old 11-15-2017, 03:19 PM   #7
D13
D13's Avatar
I appreciate the break.
Going to have to look around for W&G at a good price. Fortunately all out of painting weather here in MI. Sigh....
1987 2 ton
Old 11-16-2017, 11:46 AM   #8
72HuggerK20
I actually like painting in the winter more than the summer. It's easier to heat an area than to lower the humidity.
72HuggerK20 is offline   Reply With Quote
Old 11-15-2017, 07:55 PM   #9
sevt_chevelle
Not all W&G is created equal. PPG for instance has or had 3 different ones. DX440, DX330, and DX103(I think). DX440 was their heavy duty grease remover, 330 was the typical pre prep for paint W&G and 103 was the waterborne.
If you are cleaning dirty greasy parts, Id start with DX440, hell of a lot cheaper then brake cleaner.
Old 11-15-2017, 08:26 PM   #10
sprint_9
sprint_9's Avatar
Put your WG remover in a good spray bottle and spray it on the parts, wipe it once with a clean rag. This is a good way to use it when your ready to paint and have the part pretty clean.
If you are going through alot of WG remover and brake clean, buy them in bulk and put them in your own sprayer, might save quite a bit just doing that.
sprint_9 is offline   Reply With Quote
