04-26-2017, 11:56 AM | #1 |
Sandblast Fuel Tank?
Trying to insure my tank is ready for some sealer, but I still have a few areas, I'm unsure of. Someone mentioned trying to blast the rust out, which in passing sounded like a good idea....
Issue is, my experience has been that when sand blasting a lot of static is sometimes built up and thus it worries me. Am I thinking correctly and thus wise NOT to blast it without experience in doing so, or am I over thinking? I suppose it could be grounded but I really don't want to take any chances. |
04-26-2017, 12:21 PM | #2 |
Re: Sandblast Fuel Tank?
Blasting inside or outside?
Inside needs to be cleaned with steam. Outside could be bead blasted with something other than sand. |
04-26-2017, 01:26 PM | #3 |
If the inside has enough rust that you think it needs sandblasting, time for a new tank. Even if you can get all the rust out, the tank will have a lot of thin spots where the rust used to be. And if the rust is bad enough, you might wind up with a sieve.
Compare the cost of cleaning, sandblasting, and sealing vs the cost of a new tank. And you are correct to be worried about fumes in a used tank exploding. |
04-26-2017, 02:26 PM | #4 | |
At this point, I lost a bit of confidence in the cleaning place and have somewhat decided to try to see what I can come up with. POR-15 swears that with their degreaser, rust neutralizer and sealer even a rusty pitted tank can be salvaged. That said, I have noticed no pin holes and the outside and inside looks pretty good. The issue is just that there was about 10gallons of gas sitting in this tank for the last 15yrs. The way I see it, the tank shop cleaned it about 75% with steam, then the welder had to do something to keep from blowing up. I've cleaned it several times with gallons and gallons of high pressure water and several times with degreaser stuff. Last night I tried to let treat it with the rust neutralizer and it's looking probably 75% good. Lots of very clean metal, but still a few areas, I'm not sure about. Maybe I'll try degreaser again and then more rust neutralizer. I'll forgo the blasting, because I like to remain alive and in one piece and that worries me. Yes, I'm talking inside. Outside, I'm not worried about, I think it's close to ready for paint there. Any harm in running another larger filter somewhere on the frame rail to try to catch anything large that come through? I'll have a new pickup assembly with new screen, so maybe not needed... |
04-26-2017, 02:47 PM | #5 |
Here a picture, not as bad as it looked earlier. Must be drying....
04-26-2017, 03:15 PM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I've restored many vintage bike tanks, with the amount of of money and labor involved to line a 20 gallon tank with Por-15 you'd money and time ahead to replace that tank. With that said, I saved a 10 gallon 1955 Siegler Oil Heater tank about 7 years ago with fiberglass. After cleaning the tank I held it up to the light and there were so many pin holes that it resembled stars in a night sky. I just simply wrapped the tank using fiberglass cloth and resin and it's still drip free and dry as a bone today. I've used it to heat my shop for 7 years now using diesel fuel, kerosene, among concoctions of mineral spirits, motor oil, and old gasoline. If you go with the Por-15 do not take any short cuts and follow the instructions to the letter! Make sure product you do use is ethanol compatible because many are not and will deteriorate with various solvents. "Just Sayin"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
04-26-2017, 04:21 PM | #7 |
Time for a new tank.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-26-2017, 04:29 PM | #8 | |
As for saving money on another tank, I'm already $100+ in on this tank and it is not porous and doesn't have any areas that appear to be thin. The other thing is, I'd love to be able to get a spot to store my spare back up under the truck and I can't buy another tank that'll allow that. If it held gas for 15yrs in a field, there aren't any leaks....just want to keep it that way!! The welding shop wants $600ish to build a tank and all aftermarket tanks I've seen are well over the $200 mark. If I'm missing something or if it appears I'm cutting corners I'm open to input on that.... Feels like I'm going overboard to insure I get a good result. I think, minus fuel filler, I'm only out $100-150 at max and stuff like the cleaner/degreaser and the etch, I've been using elsewhere so that's sort of in material cost but I've figured it into that number. |
04-26-2017, 06:15 PM | #9 |
Active Member
Just as an fyi.
You don't mention year/model of your truck but some of the Spectra fuel tanks are very reasonably priced and probably the best quality and fit for our old trucks. They used to be made in Canada and probably still are. I bought one for my 68 about 15 years ago for about $170. You truck may be cheaper.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
04-26-2017, 06:38 PM | #10 | |
04-26-2017, 11:15 PM | #11 |
60-66 Nut
If that was my tank I would buy several gallons of vinegar and dump in there and leave it for a couple days. Then pressure wash/steam clean it and the rust should be gone. Don't forget to have the filler neck resoldered prior to sealing the tank.
04-26-2017, 11:19 PM | #12 | |
Will a carwash work for the final clean? I've been using my well water, about 35 gallons per minute, with a small nozzle. It works pretty darn good. I'll have it soldered first, the welder said bring it after sealed, but I think I'll take it to him first. |
04-27-2017, 02:03 AM | #13 | |
For tank coatings, Ive used motorcycle tank sealers with good success. Ill try to find the name of the sealer.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
04-27-2017, 05:24 AM | #14 | |
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 04-27-2017 at 05:31 AM. |
04-27-2017, 09:11 AM | #15 |
Evaporust, molasses/water and citric acid all remove rust through selective chelation. There are other chelators as well. Evaporust is fast and expensive. They don't attack the material itself. Phosphoric acid is also a good rust remover that is not hard on the steel as well.
Saskatoon, Saskatchewan Canada |
04-27-2017, 05:37 PM | #16 | |
Welder can't get solder it until Monday, so I guess I'll wash out my metal prep this evening and if still have some rust then I'll go buy vinegar....how many gallons is enough for a 15 gallon tank? ***I just looked something up and it says to possibly add salt to the vinegar to help as well, creates a different reaction. Sounded like a gallon or two mixed with 1-1/2-3cups of salt is enough. Then they say to neutralize with baking soda/water mix, then the WD-40 and fill with fuel. This adds to the questions.... 1) Is the vinegar followed by baking soda mix ok IF I decide to seal it with the POR-15 or do I skip this step and seal it? 2) If I decide not to seal it with POR-15, is the WD-40 ok to apply before going in to have neck soldered back on? I'll post updated pictures once I rinse it back out. Last edited by MASTERBrian; 04-27-2017 at 05:47 PM. |
04-27-2017, 11:06 PM | #17 |
60-66 Nut
I have never used vinegar in a gas tank. I do use it quite frequently on the products that I fabricate to remove the mill scale. Then I neutralize with a water and baking soda mix and then rinse with clean water. You will need enough vinegar to submerge all of the rust in the tank. I would also forego any tank sealer and just coat with some sort of light oil.
04-28-2017, 04:25 AM | #18 |
Do not use WD-40 or any other light oil before soldering or before using the Por-15. Once that neck is soldered (depending on how much crap enters the tank from the soldering process) then use either the Por-15 or the light oil. The idea for the use of the oil is to stop the rusting process that immediately begins when the clean steel is exposed to air. (oxygen)...Thats why in days of old when gasoline was really gasoline and you stored a bike or a boat, "or a tractor" for any length of time you fill them. "Simple science" once upon a time until moonshine was added to gasoline to please the tree huggers...
