Old 05-05-2012, 02:51 PM   #1
nychevyman
nychevyman's Avatar
4l60E trans swap question
is there an advantage/disadvantage to using a 4l60E over a 700R4? would it be a direct swap?
nychevyman is offline   Reply With Quote
Old 05-05-2012, 02:56 PM   #2
gearheads78
gearheads78's Avatar
Re: 4l60E trans swap question
Are you running F/I? You need the electronic controls to make the 4l60e to work. If you are running a carb just use a 700r4
gearheads78 is offline   Reply With Quote
Old 05-05-2012, 03:23 PM   #3
nychevyman
nychevyman's Avatar
i'm running an edelbrock 1405 carb on a 400 sb.
My transmission is whining like crazy and i'm afraid it is on its way out.
I am trying to figure out all of my options. anyone know what the average cost is for a shop to replace the pump in a 700r4 is?
Old 05-05-2012, 07:53 PM   #4
clinebarger
Have it rebuilt & buy a converter.....DO NOT half a$$ a 700R4.
Have it done NOW....Dont wait for it to break.
The converter & front pump can make whining noises.
clinebarger is offline   Reply With Quote
Old 05-06-2012, 10:21 AM   #5
nychevyman
nychevyman's Avatar
Ok, will a turbo 350 bolt right in till the 700 gets done?
It looks like it is all the same
Old 05-06-2012, 10:44 AM   #6
oldgoalie
If your truck is a 4X4 it won't just "bolt in", not with out a lot of other changes. If your truck is a 2wd it would fit, but you would have to move the crossmember foreward, and you might have to change the driveline, depending on which 350 you have.
oldgoalie is offline   Reply With Quote
Old 05-06-2012, 05:19 PM   #7
nychevyman
nychevyman's Avatar
its a 67 2wd with a 400SB. i can move the crossmember easy enough. i just need the right tail length then?
Old 05-06-2012, 05:25 PM   #8
clinebarger
A 9" tail TH350 is a direct bolt-in, Just move the crossmember forward to accommodate the TH350 mount location.
Old 05-07-2012, 06:27 PM   #9
nychevyman
nychevyman's Avatar
i went to pick up a 350 trans listed on craigslist last night and it turned out to be a 700r4. it came out of an 89 chevy and is a gm rebuild. it was in a 2wd 350 truck. wish me luck.
