Old 05-14-2019, 02:40 AM   #1
Roarinrat
The Door seals donít
Hi
I have got the door shut lines on my 56 GMC perfect, and installed new door seals. The problem is that they donít fit at all well, to the extent that I can see daylight through the leading edge of the door when Iím in the drivers seat.
At 60 mph itís like a windy day in the cab.
The seals are made by Counter Part.
Has anyone had a similar experience with Counter Part seals, or is there an alternative maker that has a larger cross section seal?
Looking forward to hearing you thoughts.
Steve
Roarinrat is offline   Reply With Quote
Old 05-14-2019, 10:00 AM   #2
01spirit750
Re: The Door seals donít
It "might" be an issue with how you installed them. The direction that the door seals install is a bit counter to what you would think.
The narrow part of the seal is glued to the door and the wide part is the sealing area.
Hopefully someone on the forum can post a picture.
It seems odd the the gap lines and doors are flush to the body but you can still see light or gaps.
01spirit750 is offline   Reply With Quote
Old 05-14-2019, 11:15 AM   #3
Roarinrat
The seals aren't glued, but retained by small barbed plastic pins that push into holes in the door skin.
Old 05-14-2019, 11:25 AM   #4
Roarinrat
Doh!
Taking 01spirit750's advice, I think I have put the seals on the wrong way round...
I just found a thread on this site that links to an guide on the Brothers site that shows how to install the rubbers, including a picture of how not to do it, which looks exactly like the way round I have mine.
I'll swap them over, an let you know how I get on.
Old 05-15-2019, 08:13 PM   #5
_Ogre
_Ogre's Avatar
your not the 1st one to do that, ogre did it too
nice thing is it's an easy fix if you used the pins
shop air compressor timer
Old 05-16-2019, 02:24 PM   #6
MD2020
Yea I have a 56 also.
so I need to here how good they work.
MD2020 is offline   Reply With Quote
Old 05-16-2019, 06:39 PM   #7
my56chevytruck
my56chevytruck's Avatar
As my friend OGRE said, some have made mistakes installing the seals, I did to and it sure was a noisy 1st ride
RUBBER DOWN AND HIT THE ROAD!!!
my56chevytruck is offline   Reply With Quote
Old 05-17-2019, 02:57 AM   #8
Roarinrat
Turned them round - problem fixed!
Thanks for your comments
Old 05-25-2019, 11:23 AM   #9
Russell Ashley
Russell Ashley's Avatar
Most of us have done that. I did it with my last truck and they were glued on so it meant buying new ones.
Russell Ashley is offline   Reply With Quote
Old 05-28-2019, 11:27 AM   #10
57tailgater
Can you post a picture of how they should be for future reference for all?
57tailgater is offline   Reply With Quote
Old 05-28-2019, 12:10 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
If they look like they're on there right, they usually aren't.
The way they fit is counter intuitive. They do NOT conform to the shape of the door edge. Instead they "fold" to seal when the door is closed. Also, even though I got hot pants and didn't, everyone who wants the best should use Steele Rubber.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 05-28-2019, 04:18 PM   #12
Roarinrat
Rather than me posting pictures, just type in ďdoor sealsĒ into this sites search function, and you find that my mistake has been made by many others, and they have posted pictures to show the right way to do it.
Luckily for me I hadnít glued the seals down, and managed to reuse all the plastic pins again.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
