05-11-2018, 08:42 PM | #1 |
Calling all big block wizards
Do the brackets on this engine look similar to a truck engine? would they work for use in a 68 c10?
Yeah' well sometimes nothin' can be a real cool hand Lucas Jackson |
05-11-2018, 10:00 PM | #2 |
Re: Calling all big block wizards
Where’s the pic?
05-12-2018, 12:05 AM | #3 |
Sorry I'm Having trouble loading it.
05-12-2018, 09:26 AM | #4 |
your water pump is the key factor for your brackets. Long pump a d short pump have different brackets
Tom in Iowa 68 L88 C10 68 4x4 C10 soon |
06-05-2018, 01:46 PM | #5 |
If you're not looking for a period correct set-up, I went with a Kwik performance set up and used the serpentine set up off the 91 GMC small block I swapped out for a 454. It's 4 plates that bold to the heads and lower acc holes on the block. It called for a reverse flow water pump and a 1 inch longer belt. Easy to install, nice workmanship on the aluminum pieces and uses stock belt.
