Old 09-12-2018, 12:27 PM   #1
Willie G
Head Gasket Install
Hello all, Im about to install my head gaskets and noticed that the new head gasket is different from the old. Its an LQ4 engine bored .030 over, with flat top pistons, and a LS6 cam. Is this the correct head gasket? Pics. 1st pic is bare block, 2nd pic is with the old gasket and last is with new gasket.
Willie G is offline   Reply With Quote
Old 09-12-2018, 12:52 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Head Gasket Install
As long as the gasket isn't blocking a needed hole, or lacking gasket on a sealing surface, you should be fine. The GM LS9 gasket is a favorite IMO.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-12-2018, 06:28 PM   #3
Willie G
So the new gasket looks like it is blocking off the water ports to the head. Got these gaskets in a rebuild kit and everything else fits just fine. Is this a new design gasket? Just trying to verify that this will work and not be a problem.
Old 09-12-2018, 10:19 PM   #4
sprint_9
sprint_9's Avatar
You need to have those water ports open. I think I would be tempted to buy different gaskets as yours dont look right.
The hole is there in the black layer but blocked off by another layer it looks like. Here is a picture of a GM gasket, it shows the water ports that should be open.
sprint_9 is offline   Reply With Quote
Old 09-12-2018, 10:56 PM   #5
Willie G
I agree. I'm buying new gaskets to be sure
Old 09-13-2018, 06:41 AM   #6
homemade87
Looks to me you have it on upside down on that side . Those open ports are in the rear of the block . Flip it over and put those opening to the rear of the engine and I would bet it would fit .
homemade87 is offline   Reply With Quote
Old 09-13-2018, 12:28 PM   #7
truckdude239
truckdude239's Avatar
Gasket is backwards
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-13-2018, 08:22 PM   #8
Willie G
No matter which way I put these on, they still cover up the water passages. New ones arrive tomorrow. We shall see how those come in. Thanks again for the support.
Old 09-14-2018, 08:31 PM   #9
Willie G
Thanks again gentlemen. New gaskets arrived today. Much better
