02-17-2018, 11:39 PM | #1 |
Front grille 72
Hello guys, I need some advice or suggestions. I have a 72 highlander ,the front grill is original. It is very pitted on the outer shell and faded on the inner grill. Should I buy a new grill completely or keep it and just paint the inner part of the grill? I'd like to keep it somewhat original as I restore it. If I do paint the inner part what color should I go with? And is there anything I can do to help the pitting on the outer? Any suggestions or advice?
Thanks |
02-18-2018, 12:26 AM | #2 |
Re: Front grille 72
The outer, if original, should be aluminum - should just need a good polish? Im sure there's posts on here about restoring them. Can you post a pic of the pitting?
The inner I've seen people paint them black, or maybe "argent silver" is coming to mind for a close to original color. I had planned to paint my inner but upon inspection the plastic was way more cracked than I anticipated. Good luck. |
02-18-2018, 12:41 AM | #3 |
Re: Front grille 72
From a distance and in the sun it looks okay I'll share a up close and distance picture.
02-18-2018, 12:57 AM | #4 |
Re: Front grille 72
Ok - yeah that looks like it's just oxidized. Do some research on polishing up old grills. I think i recall something about removing the old anodizing...but i'd bet you can bring it back to life.
Check it: http://67-72chevytrucks.com/vboard/s...d.php?t=330045 Last edited by SeventyOne; 02-18-2018 at 01:26 AM. Reason: found a link |
