09-09-2018, 03:59 PM | #1 |
Intermediate shaft
I have a hardened on the way, but have any of you ever seen a stock shaft fail with a HV oil pump? Damage...pictures?
Patch |
09-09-2018, 04:23 PM | #2 |
Re: Intermediate shaft
the plastic coupler tends to be the p.i.t.a .
aftermarket with steel sleeve and pined work good .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
09-09-2018, 04:40 PM | #3 |
That's what I have ordered. Almost didn't swap that out.....think that would have hosed me.
Patch |
09-09-2018, 05:25 PM | #4 |
few cents now cheeper than stack of hundo's later . . .
09-09-2018, 05:55 PM | #5 |
Patch |
09-10-2018, 12:05 AM | #6 |
common cents goes along way. you want plastic or metal
09-10-2018, 12:16 PM | #7 |
Common sense? My question had nothing to do with the collar originally. I was asking about the rod material strength, stock over the replacement and if anyone had any experience with a failure on one.
Patch |
09-10-2018, 05:12 PM | #8 |
oh sounds like you got offended, sorry I didnt mean to go down that path. I think you got your answer as far as a hardened shaft and not to use plastic.
I guess I was really bored and replied to such thread that already seemed to be a dead horse. |
09-10-2018, 08:42 PM | #9 |
No Sir.....not at all. Was just clarifying.....no worries!
Patch |
09-11-2018, 10:54 AM | #10 | ||
"I ain't nobody, dork."
In all the SBC's I have torn apart in the last 35 years, I have never seen an oil pump shaft failure. I've had the plastic collar in pieces in the bottom of the oil pan, but the shaft has never failed. I've reused many of them (with new collar) without issue.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
09-11-2018, 11:15 AM | #11 |
Thank's Gary! Mine was burred up a little on the outer ears, but nothing major. Without that collar on there, I do see it flexing quite a bit. Just curious if anyone has ever seen a catastrophic failure on these.
Patch |
09-11-2018, 02:10 PM | #12 | ||
I never have, but I'm sure some have failed at some point. I spin my 355 up around 7,000 RPM's once in awhile and it still has the original pump shaft in it from 1972.
I see you're in Oak Harbor... so am I. Gary
09-11-2018, 11:28 PM | #13 |
60-66 Nut
I have seen a failed stock oil pump shaft in a big block with a HV oil pump. It supposedly happened during the winter when revving the engine while it was cold.
Thread Tools | |
Display Modes | |
